Matt Perger's new tamper - Page 2
The smaller size is actually to accommodate slight manufacturing tolerances.
I fully disagree, I have a 58.4 Reg Barber and a Pergtamp which is 58.5 and there is a noticeable consistency bonus with the larger size and its obvious its fits the basket better.ds wrote:Probably because it just does not matter... 58.4 or 58.5 the difference is 0.1mm and I can't believe anyone would be able to taste difference between those two...
You're still ignoring Perg's huge multi slide spiel (with diagrams, etc) on why 58.5 is a must for VST and then he just does 58.4 for the cheaper one with no explanation.
Tolerances in the machining of the tamper base?LukeFlynn wrote:The smaller size is actually to accommodate slight manufacturing tolerances.
"...The main reason is for compatibility with VST baskets. I want to make sure that every tamper fits every VST basket.sluflyer06 wrote:Did nobody else notice that in his material for the BH tamper he says "58.4 to fit VST baskets"...and his PergTamp is 58.5 for VST baskets???
Is he possibly nerfing the cheaper tamper to favor his PergTamp?
He gives a long winded explanation on why 58.5 is the magic # for a tamper but then abandons it suddenly with no explanation on why 58.4 was chosen for the POM tamper.
58.50 had me receiving lots of complaints about jamming. The basket/tamper only need to be dropped/hit hard a few times to cause minor deformation, which drastically affects diameter, resulting in an interference fit (jamming).
After talking with Vince at VST, we've concluded that this dimension should avoid all of that, leading more good vibes and easy tamping times. "
Pulled from the comments section on barista hustle
Good to know, though I've tried a fair number of vst baskets with my perg and the fit is beautiful. Although I'm very careful with my stuff.
- yakster
He explained the change.
-Chris
LMWDP # 272
LMWDP # 272
The basket. I believe VSTs main focus is to ensure that, most importantly, the hole size and amount is identical... The actual rim diameter has very slight variants.sluflyer06 wrote:Tolerances in the machining of the tamper base?
Also, it's not a fair comparison between a 58.4 reg and a 58.5 perg IMHO. Reg's don't have that very sharp edge, which is likely what is really changing/improving things rather than the 0.1mm size increase.
- aecletec
He takes his guesses far too seriously.sluflyer06 wrote: He gives a long winded explanation on why 58.5 is the magic # for a tamper but then abandons it suddenly with no explanation on why 58.4 was chosen for the POM tamper.
AKA fines are bad then fines are good.
- yakster
The explanation was in the commentsyakster wrote:He explained the change.
Robert D'Alessio
6 days ago
Hey Matt, what is the difference between the Pergtamp and this tamper? I can see that the Pergtamp is 58.5mm vs. 58.4 for this one. As you were involved in the design of both, why the difference?
Reply
Matt Perger
3 days ago
Hey Robert! The main reason is for compatibility with VST baskets. I want to make sure that every tamper fits every VST basket.
-Chris
LMWDP # 272
LMWDP # 272
