Making a hard boiled egg with your espresso machine?
- LaDan
My cast iron skillet was oily, and I was too lazy to go clean it.
Was also too lazy to boil the egg in a saucepan.
Instructions:'
Tools needed:
1. Small milk steaming pitcher.
Method of preparation:
1. Place egg in the pitcher.
2. Fill with water.
3. Steam, using the espresso machine steam wand.
4. Place on the side, set timer to 5 minutes.
waiting....
I think I am on to something great.
Touching the hot water, and it is lukewarm. OK, the egg was cold, so it makes sense.
5. Steam the pitcher/water/egg again.
6. Restart the timer. 5 minutes.
waiting....
Touching the hot water, and it is kinda still hot. Thinking for a couple of seconds, I decided to re-steam the water.
7. Steaming, restarting the timer. 5 minutes.
waiting....
Touching the hot water, and its still hot. I realize that the hot water indicates that the egg is already hot too. I think, if I put a thermometer in, and chart the speed that the water lose temperature I will be to accurately predict how hard the egg is and when it is ready.
OK, time to make the sandwich.
Stay tooned.
Instructions:'
Tools needed:
2. Fill with water.
waiting....
waiting....
waiting....
Stay tooned.
- TomC
I bet IV antibiotics take much longer.
- galumay
I use my Caravel with PID to do slow poached eggs, sous vide style. Put the eggs in the kettle with the PID set at 64deg C and leave for 45 minutes = perfect poached eggs!
LMWDP #322 i started with nothing.........i still have most of it.
- LaDan (original poster)
Interesting sous vide.
I guess, next time I could use the larger steam pitcher for more hot water, and steam until it boils.
At least I know that I would not get worse than a soft boiled egg.
Try scrambled - that works quite well, but can get a bit too wet unless you have really good steam.
Never as good as a pan+butter then cream just when it's perfect to stop it cooking though.
Love scrambled egg even more than poached, but only just.
- yakster
You can use a PID La Peppina kettle for sous vide cooking too, as documented here: Choosing a thermocouple for a La Peppina.
-Chris
LMWDP # 272
LMWDP # 272
- iginfect
use the hot water tap and let stand 15 minutes on the stove w/ very low flame.
if the frypan is clean except for oil, heat it up, add eggs and fry.
marvin
marvin
