Mahlgut Adjustable Tampers - Page 4
- aecletec
Of course the tests are conducted within reasonable parameters, not half a gram tamp etc. 5-30lbs was the range I recall for Socratic and higher for others. I like to design problems out of my work flow so I usually use frozen beans in a single-dose with tapping to settle and lightish tamp/level and can't notice a difference in my pulling between doing that and pushing much harder.
I might add nutation etc if I'm going crazy on specific beans.
- weebit_nutty
I think you misunderstood my comments. I'm not suggesting the tests are in any way flawed. The problem I have is against what you're saying--you are going on the assumption that your roast conditions are exactly the same from day to day. they aren't. and that is not reflected in the tests. Wanna test this? Swap out the beans from medium to dark or from fresh to not-so-fresh (within reason, say 2-3 weeks). Don't adjust your tamp level/pressure on the push tamp. I can guarantee you extraction time will be off unless you recalibrate your push level to account the reduction or increase in flow due to those changes... Or you will have to adjust your grind or dose (which means you're changing more critical parameters that affect flavor just to accommodate the fixed tamp level.
Tamp pressure might not have an affect extraction when all else is equal all the time but at home it rarely is. Home baristas work through roasts until they're done and then change roasts constantly. But they don't dial in the roast constantly they're making incremental adjustments to the tamp level without even knowing it. A push tamper won't allow for that.
- aecletec
I'm not assuming anything, I'm drinking it.
Tamping works that way and I know because it's a levelling tamp that I use the same way between 14-15g. I find freezing works great with regard to infrequent grind changes. Please tell me more things that I apparently believe.
- RioCruz
I agree with Chris and Dan. I've used mine almost every day for several years and once I got it dialed in for depth and resistance, I've never had any reason to change the setting no matter which coffee I'm using. BUT...obviously, opinions here will vary...HBchris wrote:For those that have this tamper, or a tamper style such as this, when you get in a new coffee how do you determine the depth level to make the tamper.
As I am assuming, when changing coffees, the tamper depth would need to change.
"Nobody loves your coffee more than you do."
~James Freeman, Blue Bottle
- TomC (original poster)
I'm all set to click submit on my order, then I see nearly 70 Euros just for shipping two tampers. That's four times what was posted on page one for a guy to get one tamper sent to LA. I emailed them about it, hoping for a more realistic option. It didn't even state the method, DHL or other, just "standard shipping".
And don't forget customs. Cost me a bit over $40 for that.
Ira
Ira
- mrespresso23
Seriously thinking about getting me one, but need some reassurance.
Anyone using it with a Linea Mini?
Some open questions:
1. Should I go with 58.5 size?
2. Thinking about the palm wood with depression, but given that it is lighter, I am not sure if it wouldn't be better to go with SL or the all metal one.
3. Flat / Convex - I'm thinking convex.
If you're using it with a Linea Mini, please do share your thoughts and choices on the above questions.
ira wrote:And don't forget customs. Cost me a bit over $40 for that.
Ira
Others have noted that they didn't get hit with duties/customs, but I'll add that I heard back from Mahlgut, they said it's cheaper to buy each separately, because DHL shipping goes up astronomically once the package exceeds 2 kilos. I'll be placing my order tonight for one, and I'll update the thread if I get hit with duties/customs fees.
- spressomon
The palm tamper, especially aluminum variant, might fly underneath the US Fed's import tariff radar. OTOH all the Grist MG-1 grinders, including my original single unit order, ended up with a tariff payment required.
No Espresso = Depresso
I have a Linea Mini and have been using the Mahlgut Tamper Palm for over a month. The Mahglut Palm is great (and I prefer it to the Saint Anthony Industries "LEVY"), even though it's a little heavy.
2) I have the 2.5 pound Mahlgut Palm (not the lighter metal-based SL or wood handle version) and I wished I had spent the extra 10 euro for the lighter version
3) I prefer FLAT, but I think this is an issue of personal preference.
For those entering the discussion, in the The Levy Tamper - Saint Anthony industries, thoughts? thread Randy G argues some excellent points against the palm-based tamper:
1) Yes, if you have VST baskets (I do, and the tamper fits like a glove)mrespresso23 wrote:Seriously thinking about getting me one, but need some reassurance.
While I do not have a reasoned rebuttal to any of Randy G's claims, I've been using palm-based tampers (i.e. the Mahlgut Palm and the Saint Anthony Industries "LEVY" before that) for a few months and haven't encountered any evidence to support his claims against them. Maybe that's a testament to the consistency and stability of the Linea Mini. Or maybe I have no idea how to pull a shot correctly. Who knows--but I love the Mahlgut: it's easy to adjust, natural to use...I simply wish it was lighter. If it had the mechanics of the "GREAT LEVELER", it would be the perfect tamper (for me.)Randy G. wrote:I feel like I missed a week of class in an advanced engineering course, and upon returning to school feeling quite lost. Has someone come up with some evidence that a tamping method based on force-priority is inferior to a tamp that is solely based on depth? Is not tamping about the goal of compressing a mass of coffee that offers a consistent amount of resistance to the flow of water throughout its three-dimensional area. To achieve that don't we desire two things - consistent compaction and a level bed of coffee?
These various depth-priority tampers will possibly present a level tamp, and can be used to create a tamp at some force, but the odds of both happening every time is relatively slim without multiple adjustments throughout the day in a commercial environment, or by luck as much as anything else in a home environment. In either case, they seemingly depend on on a precise volume of coffee when compacted which is more difficult to measure than a mass of coffee.
And in terms of a level tamp, I theorize that it is easier to get that AND a measured or sensed tamping force by having your fingers on the top edges of a standard tamper's base and using tactile feedback by sensing the top of the basket and the top edge of the tamper's base concurrently.
So these have replaced the long-used mass of coffee with the need for a volume of coffee to get a level tamp through their design. And they have replaced tamping force with depth to make use of their leveling feature. And you get both when you add a dash of luck (getting the correct volume and grind to get the correct compression when the tamper bottoms out on the top edge of the basket) There are tampers that allow a level tamp every time, and some that give some sort of feedback for tamping force (which is overrated to an extent).
Isn't this just making things more complicated? Adding variables instead of eliminating them? I don't weigh myself in the morning with a ruler, so why by restricted to tamping to a depth to get the desired compression? And the design of the handle (the mushroom "handle") eliminates the ability to feel the how level the tamp is when the handle does not seat on the basket at the end of the tamp in instances where the device does not hit the basket.
And even if we discount all of that and say that the only thing that matters is level and just smash the coffee down because after about 35 pounds of "force" it really doesn't matter any more, why not use a tamper that is specifically designed to tamp level every single time without fail like the "Easytamp 5 Star Pro" or the 'Great Leveller"? Or just use a tamper and tamp level?
After spending years learning how to eliminate variables this all seems counter intuitive and counterproductive to me. And, maybe, just like these new "puck" tampers, I am overthinking this... But if we want to complicate this, I think I would rather have a rechargeable tamper with a built in vibrator that creates an even distribution before tamping. A number of jokes just came to mind, but let's not go there.
