Mahlgut Adjustable Tampers - Page 2
Want to talk espresso but not sure which forum? If so, this is the right one.
tohenk2
#11: Post by tohenk2 »
I would like this locking mechanism on the OCD-tool.
mrespresso23
#12: Post by mrespresso23 »
Can any one suggest what would be the best size to fit a stock La Marzocco Linea Mini basket?
I am thinking about buying this tamper together with a Tidaka funnel for my LineaMini / Ceado e37s grinder.
Also debating between flat and Convex - Thus far I have only been using convex tampers (espro, Chris Coffee, and now the stock La Marzocco which has been my favorite as far as fit).
Advertisement
weebit_nutty
#13: Post by weebit_nutty »
My beautiful crafted SAI tamper has a base that is 58.5 and fits the stock basket perfectly. Very clean tamp .. Purchased it directly from La Marzocco so I knew it was going to fit perfectly.
mrespresso23
#14: Post by mrespresso23 replying to weebit_nutty »
Which one did you get? The SAI custom temper looks amazing.
tohenk2
#15: Post by tohenk2 »
tohenk2 wrote:I would like this locking mechanism on the OCD-tool.
Oh. Wow. I'm late to the party. In the OCD-tool thread there already is a link to a Mahlgut version ...
mrespresso23
#16: Post by mrespresso23 »
FYI,
A quick search on Aliexpress, produced the following two tampers:
One seems very much like the Push Tamper ($84 with free shipping):
http://www.aliexpress.com/item/1pc-Prof ... 86711.html
The second one for $49 (not clear how one adjusts the depth):
http://www.aliexpress.com/item/1pc-Prof ... 35852.html
weebit_nutty
#17: Post by weebit_nutty »
mrespresso23 wrote:Which one did you get? The SAI custom temper looks amazing.
Yes it's quite nice. I've been using it regularly and it's a treat.
I have the two-tone Statesman Lion tamper.
http://home.lamarzoccousa.com/product/s ... mper-lion/
Very clean line, though be aware if you use the ridged stock basket, the ridges will retain some grounds. There really is no getting around it unless you apply a little scraping technique for perfectly spotless tamp (I don't recommend bumping, though it's a common technique).
Or you can simply buy a ridgeless version. :) I use Espresso Part's high precision ridgeless and the tamper does a nice job on that one tool.
Remember, virtually every LM basket I've used has a slight curved profile, so there is a specific zone where the gap between the tamper and basket is smaller than the smallest grind partical, and there is the dead end, when the tamper stops. Some basket have a bigger zone than others. On the stock ridged basket, this zone is just below the ridge, right where it should be, and stops about 1/4" below it. The EP high precision ridgeless basket on the other hand has perfectly parallel walls and a very small gap. I don't use it much though. I like my LM ridged.. Shots come out better for whatever reason.
Advertisement
mrespresso23
#18: Post by mrespresso23 »
Thanks for sharing. For now I'm going to keep using the stock basket. Just purchased the IDR funnel, and now looking for a tamper upgrade. Yours is obviously on the short list.
TruBrew
#19: Post by TruBrew »
I have been having some issue getting an even tamp and I'm sure this would help. My concern is if I buy one of these I'll never really learn to nail down a traditional tamp.
tohenk2
#20: Post by tohenk2 replying to TruBrew »
When would you need to fall back to a traditional tamp if you have this? At home, it is normal to use what you have and like best, isn't it? And away ... if you look at the routines of top-barista's [like Sasa Sestic] they all use their own tools ... (Meaning - if you want you *can* take your tools with you!)
