Plug a slow cooker into
this, have a vacuum sealer, and read
this.
Personally, I've given up on this full panoply; but I use something similar as my main cooking method for meat and fish. I put a water filled hotel tray in a warming oven set at 125 to 150F, i.e. the desired finishing temperature, but never over the protein curdling mark of 155F). I dry rub the meat or fish, add oils, but never much liquid, wrap it in a baggie (ghetto vacuum packing = putting the bag underwater to drive out the air from the non-submerged opening), and cook it so it hits the desired temperature all through. Then heat pan or start your grill and sear for 30 seconds on each side. Voila, perfectly cooked no matter how thick or thin or non-uniform.
The difference is that with commercial grade vacuum packers, the cut will not ooze much liquid; whereas with this simplified method, you will get about a half ounce of juices from a 6 ounce portion. I'm fine with this, since I like deglaze sauces.
I don't think sous vide is much use for anything except meat/fish or the occasional Hamine egg in the same low temperature bath; but I haven't tried it extensively except for these.
