I've been reading this forum for some time but didn't jump in as I felt I didn't have much to contribute. I have been practicing espresso making for quite some time and often felt great frustration. Some of it was because I couldn't get to the desired results and some of it because I kept reading many posts in this forum, saying that basically unless you spend a couple of thousands of dollars on espresso machine and grinder, it will be almost impossible to reach good results.
I have finally decided to post here with the hope this posting will encourage beginners with low-budget to try their best even if their equipment is not as fancy as some of the names mentioned throughout this forum.
For me the starting point was to find the coffee that I like best. After many experiments I was happy to find the Toscano blend by Counter Culture. This blend is very aromatic and as flavorful. It has some mild sweetness and hints of caramel, hazelnut, and dark chocolate. Obviously coffee is mostly chosen based on personal taste but I thought I'd share mine.
The next step was to get the espresso machine and grinder. Since my budget was very limited I did quite a research and ended up with Breville Roma and Breville BCG800XL Smart Grinder. The espresso is a single pump machine and the grinder is conical burr. I am well aware this isn't the best machine out there but for the price I think Breville offers excellent value for beginners.
The espresso i produced was very close in taste to the espresso I tested in the local cafe from where I purchased the coffee beans (Octane - Atlanta, GA) so that was for me a confirmation that the grind is good.
As for frothing the milk, that was my biggest source of frustration. no matter how much I read, watched videos on you tube, read again and tried, I could not get the desired micro foam that everyone is talking about. I even thought that something was wrong with my espresso machine and contacted the Breville customer support and almost ended up spending good money in sending it to a service station. At the last minute I decided that maybe it is still me doing something wrong.
I spoke with several baristas who all told me that I will not be able to froth the milk correctly with home machine and forget about latte art unless I got one of the very expensive ones.
Then I found this excellent forum and web site but got frustrated again when I kept reading - The same theme more or less... the only way to get it right is to purchase an expensive machine.
I decided to not give up and continued to practice frothing the milk again and again - sometimes 3-4 times a day..... but still failing to get it right..... until two weeks ago! Something happened and I finally got the milk frothed correctly. It looked exactly like most of the descriptions... shiny lightly thick but not foamy.
When poured it into the espresso, I could see the foamy milk going into the coffee and then surface like a thin layer of paint but I was unable to draw anything. At this time I knew I am getting close and continued to get better and better as I improved my pouring technique.
I am happy to share these two pictures which I took this morning of my latte art: a leaf and a heart. They may not be perfect but I know that from now on it is just a matter of more practice.
My message to all the beginners: You don't necessarily have to spend thousands of dollars on equipment to make excellent espresso/cappuccino with latte art. It just takes some (very good) practice and patience.... but it will eventually work.
Heart
Flower/Leaf
