I finally found some time to do some more tests.
I retested the element as per"allon"
Unplug machine.
Disconnect heating element wires.
Measure resistance between each heating element terminal and a nice copper bit of boiler or fitting on boiler.
If you get anything less than infinite, you've got a problem with the element.
Measure resistance between element terminals. Apply ohms law to calculate what you expect the wattage to be. Make sure it jibes]
This is what i did yesterday as per OE's tech tips. only this time I also tested against the copper on the boiler and got Infinite. Also checked from ground to all the hots and they all came out infinite.
Measurement between the element terminals wavered between 12.3/12.4 and applied ohms law with online calculator and came up with 975 watts, just as another_ jim came up with.
Tried another GFCI circuit in the upstairs bathroom. GFCI tripped.
As far as I can tell,this element tests GOOD. Does it have a pinhole leak that my meter can't pickup? as Randy G. says, Maybe? I can't find any ground to hot issues. So I thinks it's time to go back to The bad old days.
keepitsimple wrote:Quite often, elements that have not been used for some time can absorb moisture - just enough to cause problems. In the (bad ?) old days, the solution was to plug it into a non-protected outlet and let it heat up. The heating will normally expel the moisture and fix it. I'm NOT recommending you do that, but it is often the case that if you can get the element heated up in some way, it will cure the problem
What the hell,either this element works or it doesn't. Before I do this does anyone have any other ideas
I can try??????
Thanks for the input.
