by Peppersass on Tue Feb 22, 2011 7:22 pm
Interesting thread. I mostly agree that straight espresso is an acquired taste, and people who are not accustomed to it will often say that a properly pulled shot is too bitter. But even home baristas who have pulled and/or consumed straight espresso every day for years have struggled with bitter shots. It's probably the most common flaw.
As HB suggested, bitterness is often a symptom of overextraction. Assuming that this has not been caused by errors in the preparation (e.g., poor distribution causing channeling) or machine problems (e.g., inaccurate/fluctuating temperature, excessive pressure, etc.), you can sometimes compensate with a "dodge" shot or an early cut-off. Other ways to deal with overextraction are to grind finer or increase the dose.
Although it's generally true that American espresso blends are designed to be updosed, I think part of the reason updosing is popular in America is because it makes it a lot easier to pull a shot that's not excessively bitter. In other words, updosing can to some extent compensate for less-than-perfect technique.
The other side of the coin, of course, is underextraction, typically caused by grinding too fine, updosing too much or cutting off the flow too soon.
IMHO, both flaws can be avoided or minimized by doing the following:
1. Using fresh, properly roasted beans.
2. Using a quality grinder.
3. Using a scale to weigh the grounds and extracted liquid so you know the extraction ratio.
4. Taking the time to optimize the dose, grind and temperature during the dialing-in process.
5. Carefully distributing the coffee in the basket.
6. Keeping the machine and basket clean.
Dick Green
