Like my post count shows, I'm a newbie. I'm the guy that found a working NS Oscar and Pavoni Zip Base grinder at a yard sale for 50 dollars.
I finished getting them all together and working correctly. The Oscar had the pod diffuser instead of the ground coffee diffuser. The Zip had a seriously jammed adjusting collar that needed to be feed up.
I was so proud of myself of fixing the Oscar by resetting it and cleaning up the Zip so that it works good.
However this weekend, my Oscar ran out of water. The light came on and the machine shut down. I put more water into it and it still didn't work. I started to freak out. Took the cover off and started to mess around, trying to figure out why the heck this wasn't working.
Took a break and came here and decided to search before I really went nuts and disassembled the machine.
Searched for something like oscar water level empty and found some hits. Found out that you are NOT supposed to use distilled water. That was a surprised. I emptied my tank and filled it halfway with tap water and the distilled water and bingo! Everything works well again.
So thanks for this site and the search feature. It really has helped get my little setup up and running.
