napierzaza wrote:I have recently started freezing. I had put them in ziplocs and then a jar in the freezer. Unfortunately after only being in the freezer a few weeks I tried some and they didn't work out very well. One tasted only of black currants after the freeze, and others seemed much more simple than they were originally. It's just my experience, but I don't think I'll be continuing to freeze my coffee anymore.
Check the temperature of your freezer. Inexpensive refrigerator/freezer thermometers are available at kitchen supply stores and kitchen departments of big-box stores.
Freezer temperature is directly related to how long most food, including coffee, will last. For example, I've seen one claim that for every five degrees above 0F, the food storage time is cut in half, and that the lower the temperature below 0F, the longer the food will last before deteriorating.
Most kitchen refrigerator freezers are set by default to 0F, or 32 degrees below the freezing point of water. If I set my freezer to the lowest setting, it gets down to about -10F or so. It's been claimed on this site that dedicated freezers can get down to -40F, but I've not been able to find any temperature range specifications for these products. The only ranges I've found have been for lab freezers, which get down really low.
So, my advice is to measure your freezer's temperature. If it can be set lower, try that and see if it extends the amount of time the coffee can be used.
I've found that freshly roasted coffee can be frozen at 0F for about 3-4 weeks. It rarely holds up longer than that unless the freezer temperature is set lower (recently I set our freezer temp to the lowest possible, but don't have information on results yet.) I try to get my coffee as soon after roast as possible, anywhere from 1-3 days post roast. I freeze it immediately on receipt, and store it in the coldest part of the freezer. Most coffees benefit from some rest time after roast, which I think adds to the amount of time that the coffee will last in the freezer (i.e., it "matures" in slow motion while frozen, buying extra time in the freezer.) So don't wait for the coffee to hit the peak after roast before you freeze it. Been there, done that, and it doesn't work as well as freezing closer to the roast date.
It also matters how you package the coffee for freezing. The container must be air tight. Some members of this site just tape over the valve and throw the bag in the freezer. Others vacuum pack the beans in plastic bags or vacuum-sealed Mason jars. I use plain-old Mason jars, but pack them with as many beans as I can to minimize the amount of air present. A ziploc in a non-Mason (i.e., poorly sealed) jar won't cut it.
Many, including me, have found that coffee stales more quickly after being frozen. While fresh roasted coffee can be used for several days, a week or even two weeks (rarely), frozen coffee will go downhill much quicker. For that reason, package your coffee in portions that can be used before the beans stale. A Mason jar of coffee lasts 3-5 days for me, depending on the bean size and the dose I'm using. Five days is pretty-much the upper end if I freeze the coffee 1-3 days after roast. I generally buy 3-4 weeks of coffee at a time so that it doesn't sit in the freezer longer than 4 weeks.
