How to Protect Cabinetry From Heat?
Want to talk espresso but not sure which forum? If so, this is the right one.
sweaner
Postby sweaner » Mar 05, 2009, 12:56 pm
As our new kitchen slowly becomes reality, I am wondering how to protect the cabinets from the heat of the espresso machine. I will be keeping the machine in the corner of the counter top. It does produce significant heat, and of course steam. What can I put on the underside of the cabinet to protect the wood and the contents?
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
smillions
Postby smillions » Mar 05, 2009, 1:48 pm
I wouldn't recommend using any type of foam board insulation; I would be worried about condensation being trapped between the insulation and the cabinets. The cure could be worse than the disease.
You might try a melamine paint. That would seal and protect the wood, but it won't do much to stop the contents of the cabinet from getting hot. Another option might be a small fan, especially if you are on an outside wall and could vent it directly outside.
artisan coffee from around the globe
Sponsored by Blazing Bean Roasters - artisan coffee from around the globe
EricL
Postby EricL » Mar 05, 2009, 3:11 pm
If you have the typical 12" cabinet depth, when you are steaming milk the steam 'should' rise in front. I just examined our 20 year old cabinets, which are particle board on the bases, and where coffee pots have been, there is a rough texture but no real degradation of the strength. Over the Silvia, they are smooth. That's a period of about 8-9 years for the silvia, 20 years for the coffee pots in two different locations. And I would venture a guess that the silvia generates a more steam than a Vetrano, just due to all the flushing and purging of the boiler. Heat may be another issue. Maybe a discussion with your carpenter or cabinet maker would be in order. I'm sure the new kitchen will be a bit nicer than our 1980's original equipment cabinets,
cbrucecampbell
Postby cbrucecampbell » Mar 05, 2009, 3:51 pm
I do a little cabinetry on the side (and my own coffee bar). If you can, just make sure they are made out of better grade plywood - even marine grade. Then the surfacing won't matter as much. A few coats of varathane will be fine. OTOH the composites (MDF, etc...) are prone to fail in damp areas no matter how they are surfaced.
Dunno about heat. Has not been an issue around my coffee bar - yet.
Bruce Campbell
sweaner
Postby sweaner » Mar 05, 2009, 4:39 pm
Thanks everyone. The cabinets are plywood and a good grade. This is a corner cabinet, so it is deeper than 12".
Scott
LMWDP #248
jdefontes
Postby jdefontes » Mar 05, 2009, 5:08 pm
Our kitchen has cheap mdf cabinets from Ikea. A year or so of having Silvia on pretty much all of the time has totally ruined the door on the cabinet above the machine. The finish is cracking off and the "wood" is clearly swelling. At this point we're just going to leave it until we move out (which will hopefully be soon) since I don't see any way of protecting against the same thing happening if we replace the door. Moving Silvia is not an option due to space constraints. You get what you pay for I guess.
Jason
keepitsimple
Postby keepitsimple » Mar 07, 2009, 9:37 am
Hi
Are you still in the planning/design stages of your kitchen ? If so, and you've got the opportunity, you might think about raising the cabinets above where you intend to place the machine. If you can do so, it largely eliminates any heat/steam issues.
I refitted my kitchen a couple of years ago, and designed this into it, along with dedicated water/power/drainage.
I also chose aluminium/glass fronted cabinets above the coffee area, but this was more for aesthetics than anything else. Also the cabinet above the coffee area has a glass base with integrated lighting.
It works out very well.
(Apologies for the very poor picture quality)
skilled in the art of grinding
Sponsored by Baratza - skilled in the art of grinding
sweaner
Postby sweaner » Mar 07, 2009, 11:49 am
Rob, an excellent idea, but the designer (wife) would have none of it!
Scott
LMWDP #248
keepitsimple
Postby keepitsimple » Mar 07, 2009, 12:31 pm
aaaah
The advantages of being your own specifier/designer/contractor, with nobody else to have to please :D
