How should cappuccino taste?
Postby Ian_G on Thu Jun 02, 2011 1:46 pm
Before, when I made cappuccinos they had a homogenous flavour distribution: i.e. what you got in the first mouthful was pretty much what you got in the last. The same all the way through. Now I find that the flavour seems to be split into layers, so that what you get at the start is quite a bit different from what you get at the end.
I'm using an Italian blend just now and it seemed to me that as I drank it, it was metaphorically the same chord, but just played in successively different keys, as I worked my way through it. I could make out about 4, maybe 3 1/2 separate layers in the drink.
So have I just arrived at something that's been known about for ages? Or am I delusional?
I did kind of think that maybe there is a possibility that different aroma chemicals or lipids are held in differing densities of milk. Then I thought maybe as the density of the foam varies, so does the concentration of the coffee.
Any insight appreciated.
Ian_G
Postby Marshall on Thu Jun 02, 2011 4:09 pm
The biggest changes are from the effects of cooling.
Marshall
Los Angeles
Marshall
Postby mitch236 on Fri Jun 03, 2011 10:40 am
mitch236
Postby Ian_G on Fri Jun 03, 2011 2:41 pm
mitch236 wrote:Check out this discussion: Do you mix / stir your espresso before drinking it?
So it seems perfectly reasonable, that if you do not stir, you will get layers. I used to use a Bacchi and never got layers. Maybe to get layers you need finer grinding, or higher pump pressure or adjustment of some other, of the many, variables. It was a first for me.
Maybe I should say that it tasted God Awful as an espresso, but wonderful as a cappuccino. Meh, I thought it was interesting. Thanks for the replies.
Ian_G
Return to Knockbox
