miKe mcKoffee wrote:Which sounds to me like you're really not trying to come up with a realistic protocol to examine home machines in general but rather a protocol to validate your machine... Which is fine, go for it.
I don't need to validate my machine; I bought it (and the other one) a while ago and they have met my needs and continue to do so. I have no plans to replace them regardless of the results of any of this testing. Since we are ascribing motives, you appear to want some sort of amorphous testing that is irreproducible and will allow anyone to say anything about their equipment. To me, this is a total waste of time. Earlier in my life I did some scientific research and one thing you learn very quickly is to only test things you have some possibility of successfully testing.
What I have addressed from the beginning of this thread and from earlier ones on similar topics is ONE ISSUE; STRAIGHT SHOT TEMPERATURE STABILITY.
Newer dual boiler machines are being promoted with claims for shot temperature shot consistency based upon the WBC protocol, but selecting out shot sequences that don't come close to what a home user would experience (e.g. "shots 5-14" on the WBC). I'm interested in what is the temperature that you get when you walk up to your machine after an indeterminate idle interval and pull a random shot; what shot temperature do you actually get vs. what you expected to get? Throwing in frothing and other stuff not having been tested on the dual boilers (to date) just complicates matters and doesn't answer the first question. If we answer the first question, then we can go on to answering others. I would not assume, as I have said before, that these dual boilers will do all that well on frothing tests because the 110v versions are going to have the same amperage draw problems that any 110v machine will have, and if they try to brew at an accurate temperature AND froth at the same time, they will either fail to do so or they will flip the circuit breaker.
In answer to the question about varying idle periods to shorter than 10 minutes; on straight shot testing, I have a pretty good idea what my machine will do in its current setup of a low pstat setting with a small flush; the 45ml flush does not perturb the machine much and after more than 2 minutes idle period I'd just use that flush and I think the curves will be similar to what I get either in shot runs or after 10 minutes idle period. The reason I believe this is that the last 15 seconds or so of shots in these shot series I've done and posted show essentially no temperature variation on the Scace device and Fluke. This suggests to me that 45mls pulled after several minutes of idling will not have much effect. This can be tested and I have no problem with testing it.
As to using the protocol that Jim suggests, I think that is fine as long as you are going to use the information to help you work on your own machine. If instead you planned to post it and claim it was accurate enough for comparisons among machines as tested by various individuals with their own differing cheap digital thermometers, I'd say any such comparison is worthless. Mind you, I'm not suggesting that home user types rush out and drop $500 on a Scace and Fluke; this would only be for people who already have bought this equipment or who don't mind making this unjustifiable expense.
I remain interested in comparing various machines (especially older ones that have been modded) to the newer crop of machines to test this ONE SPECIFIC THING; straight shot temperature stability on random shots made after random idle intervals. This is going to be very representative of what people get in low volume usage who are looking for reproducible shot temps on straight shots. This should be of interest to others because mods (such as PIDs) are comparatively cheap to do, much cheaper than going out and buying a new $4500 machine. If someone can do almost as well with a $150 mod on their current machine as they can on a new GS3, then people OUGHT to find this interesting. Of course, I am not the arbiter of what others find to be interesting:-)
I for one do not think that tight shot temperature control matters in milk drinks; to the extent that it is worth testing, I think it should be tested later, after establishing whether any machine can really deliver a shot at a desired temperature when the shot is made from idle conditions. If we don't know whether equipment can make the stable shots without introducing other factors (like frothing) then we don't have enough of a knowledge baseline to tackle other issues like the impact of frothing, for example. Until this can be established we are talking about putting the cart before the horse.
ken
