It is all John Guest. The left 1/3 of the drawing is under the kitchen sink.
Water comes in at Stop Valve (D). Through one-way valve (14), through the double cartridge softener system from Chris Coffee (C). From there we have three outputs:
- Through the valve (5) to a sink-top faucet
- Through valve (8) to ice maker
- At the end of the line (far right), through the valve (11) to the espresso machine.
I can use the faucet (A) to flush the system when changing cartridges. It is all being run with 3/8" tubing.
If I have planned it well and have all parts I need. The total up to now is $220 including the faucet tap above the sink as well as a new Stop Valve under the sink (dual 3/8 fittings) . My pressure is relatively low so I should not need a regulator from what I have read. Easy enough to add anyway later on.
Part 2 of the story should appear in about two weeks which will cover the actual installation of the system.
