Peppersass wrote:The hardness kit is: 145300 Hardness (Total) Test Kit, Model 5-B, Drop Count Titration, 1-30 gpg, 100 tests
The alkalinity kit is: 2444301 Alkalinity Test Kit, Model AL-AP, Drop Count Titration, 100 tests
Thanks for your offer to test my water, Dick, but I had a LOT more testing than you'd want to keep track of in mind. Instead, I shelled out the cash for the Hach tests as well. I haven't done a side-by-side comparison of my Salifert vs. Hach test kits yet, but today I had a chance to test my water using the Hach tests.
Read my results
here. The link is to the same Google doc as I was using before, but I've added a new sheet with new data. I have chosen to name the sheets according to the date of the testing, so make sure you're looking at October 29th's sheet.
Some observations: In general, it appears that my Aquarium Pharmaceuticals Tests from before were probably inaccurate. Presumably as the test solution evaporates, the test values become artificially deflated, because each drop I assume) increases in its strength--meaning fewer drops to change color for the same sample. That's just my guess. However, the KH test seems like it may have stayed pretty accurate. The GH test results are way off--that or the Claris has "broken in" and is behaving differently on GH (allowing more hardness through).
The Hach test is a low-range test where each drop is the equivalent of 5 ppm rather than ~17 ppm, meaning it's much more fine-grained, without halving the number of tests you get.
Other interesting data... Note that in the last 6 weeks the TDS of my inlet water has dropped by ~50ppm TTDS. It's hard to tell the comparative makeup of the water, though since I tested
salt-based ion exchange water from last month (harvested and stored before switching to Claris), It seems safe to say that the inlet alkalinity is identical--it registered as 100 ppm with the Hach test the same as my lower-TDS water from today.
The Hach test indicates that the Claris filter allows a lot more GH through than I'd previously thought, making its numbers look a
lot more like 'ideal' water (~100 ppm mineral hardness, 50 ppm alkalinity) in terms of mineral hardness/alkalinity ratio. That's encouraging to me.
One cool advantage of the Hach test kit over the Aquarium Pharmaceutical tests is that there are 2 additives with the Hach test. The practical upshot of this is that, if you add the powder to the test water and it immediately turns blue (assuming it's supposed to start out pink), then you know it took 0 drops, meaning that there is none of what you're testing for. The AP tests don't work like this, and there's no way to differentiate 0 drops from 1 drop--you just get to assume. So, with the Hach test I confirmed 0 ppm mineral hardness on the ion exchange water... like you'd expect.
Anyway, I hope someone finds the data useful... I've still yet to do any formal comparative testing of all these water solutions. And I still need to get ahold of Tony Fischer to ask him more about how Claris works. At least today I've eliminated part of my question--it actually preserves a pretty good bit of mineral hardness.
