The product that is being discussed was, I believe, developed when corrosion problems between aluminum and copper conductors occurred in the mid-sixties(?). When aluminum wiring began appearing in homes, there were many instances of overheated outlets due to increased resistance/poor contact between the wiring and the outlet terminals. The application of this product (or similar) was code-mandated.
I have
never heard of any product designed to be applied to switch contact surfaces, other than contact cleaner aerosols. The typical arcing that takes place between contact surfaces on stand-alone pstats is taken into consideration during the design phase when anti-corrosive materials are plated onto the contacts.
At the very best, I'd be extremely wary of applying this to any contact surface that sees normal cyclic operation. Why not call the manufacturer and see what he has to say about this specific application?
