I routinely log flow, and three representative shots are shown below (this is flow into the boiler). Initial debit is ~60ml/10sec, set by needle valve. Black shot was a bit flat, so I reduced brew temperature by 1 deg C to get the blue, and flow sped up by about 4 secs (stopped it early, and didn't taste), I then ground finer to get the red - which was very tasty, and 19% extraction yield (hadn't measured the others). Comparing the red to black, the initial flow is slower, but the final flow is faster, and matches that of the more coarsely ground shot at the same temperature. That is, the red and blue end up parallel, with the same slope. I did run a couple more shots to confirm the effect (and finish the bag). All shots dosed at 18g in a VST basket, 90ml corresponds to about 36g in the cup. Coffee was a Nicaraguan SO from Hasbean, 7 days post roast, and machine a heavily modified Gaggia with two boilers (one for preheating) a cartridge heater in the group and three pid loops. Grinder is a Nuova Simonelli 75mm flat. Anyway, search didn't throw much up - so I was just wondering if others have made similar, or conflicting, observations.
