at what temperature should (1) the initial ground coffee and (2) the evaporated residue be at when the weight measurements are made?
1. Obtain a representative portion of brewed coffee - about four ounces.
2. Filter the sample through a coffee-type paper filter to remove any insoluble sediment or fine grounds. (It may be necessary to filter the brew two or three times to obtain a sediment-free solution.)
3. Using an analytical balance, weigh a small, clean, and dry aluminum dish to the nearest tenth of a milligram. Transfer a small portion (exactly 10 milliliters) of the clarified solution to the dish.
4. Put the dish, with its contents, into a drying oven that maintains a constant temperature of 221F to 230F. Let three hours elapse. During this period, the heat drives off all the water; only the non-volatile material that was extracted from the coffee remains.
5. When the drying period has ended, transfer the dish to a desiccator - a small vessel, containing a drying agent, that can be tightly sealed. In the desiccator, the dish and the solids cool to room temperature without picking up moisture from the air. This requires 15 minutes.
6. Reweigh the dish. The difference between the first and second weighing represents the amount of soluble solids in the brewed coffee expressed in grams per 10 milliliters of beverage. To obtain the concentration of soluble material in the beverage expressed in terms of "percent solubles concentration," multiply the weight of the residue by 10, which now represents the number of grams per 100 milliliters of beverage that can be directly interpreted as percent. (Note: the metric system defines a milliliter as the volume of 1 gram of water at 4C and 760mm pressure.)
AndyS wrote:Also, when I removed dried beverage from the oven, the residue absorbed water back from the air very quickly. On a .01g scale I could watch the numbers steadily spooling up. So there was a rush each time to get the measurement made asap, and I didn't have a lot of confidence in the result.
peacecup wrote:I went about it the other way - I weighed the puck before brewing, then dried it out after brewing, and subtracted the difference.
Nick wrote:Problem with this method for espresso is that depending on your particular machine, a decent amount of solubles can get sucked UP and out of the puck through a drain solenoid or similar.
