by Peppersass on Wed May 18, 2011 11:07 pm
This thread strikes a chord with me because I lived the dichotomy, more or less.
After falling in love with espresso in France and Spain, I decided that I would like to try having it every morning at home. But when I looked at the cost of the equipment, I balked. I just wasn't sure that I wouldn't tire of espresso and regret spending all that money. So, I found what I thought was a good entry-level machine with high resale value -- a venerable PID Silvia. I bought the machine, despite warnings from the experienced baristas on this site. My bad.
I paired Silvia with a Macap M4 grinder, which had received many positive reviews. In this case, I followed the advice of the experts and got a good grinder. Or so I thought.
Results were disappointing. Even with the PID, Silvia's temperature instability, lack of forgiveness for preparation mistakes and intolerance for higher doses made it very difficult to explore the extraction space. Each cup of espresso was an adventure -- despite many attempts, I simply could not pull the same cup twice. I never did learn how to steam milk on that machine.
But oddly enough, as difficult as it was to make espresso with Silvia, I got firmly bitten by the espresso bug and decided to get really serious. After only one month, I sold Silvia and bought a GS/3.
What!?!?
Yes, a GS/3. Having determined that I was in the game for the long run, I saw no point in following a long upgrade path to the very best machine. Knowing myself pretty well, I knew that I would end up there anyway, and it would be cheaper to buy the machine now rather than after a series of lesser, disappointing machines. I knew that one of the less expensive HX machines would be much better than Silvia, but I also knew that I would probably tire of the temperature dance. A double boiler machine was right for me, and I had lived long enough to accumulate the funds to buy one of the best.
I very quickly found out just how much more forgiving the GS/3 was than Silvia. But my enthusiasm was short-lived. My shots were better, and the GS/3 made pulling them effortless, but they were still not consistent. What the GS/3 showed me was that the M4 was simply not good enough. When I replaced the M4 with a Baratza Vario, my espresso world changed dramatically. Finally, I was able to produce reasonably consistent shots of very good quality. The BV was a joy to use compared with the M4, and allowed me to turn my attention to exploring different coffees and preparation parameters. It was all very good.
But small inconsistencies nagged at me. While the BV was mostly on target, it required careful adjustment and monitoring to get consistent shots. I discovered that different levels of beans in the hopper required different grind settings. My attention soon turned to the Titan grinders.
I won't bore you with what went into the selection process, but I eventually settled on a Compaq K10 WBC. This grinder finally brought me to the level that I had wanted to be at all along. The grinder is as rock-solid and repeatable as it gets. With this level of consistency, and a great single-dose capability, I was able to dial in coffees quickly and effortlessly, and explore variations in dose, grind, temperature, etc., without grind inconsistencies clouding the issue. Once you can do that, you can begin to learn to be a better barista.
One thing I must stress. My ability as a barista has gradually improved from the time I began to the present. But the greatest improvements came after I got the K10.
I have two points here:
1. I'm in violent agreement with the thesis that learning how to use inferior equipment does little to improve one's ability as a barista. It only gets in the way. What you learn are the idiosyncrasies of the equipment and how to compensate for them. You end up focusing on that instead of exploring the incredibly diverse world of coffees and roasters, and you can't produce espresso consistently enough to explore the extraction space.
2. Most of the comments in this thread have been about the machine. That's not the issue. As we all should know: "It's the grinder, stupid." Once you get to the entry-level HX machines, you can learn to get consistent performance. It may take some dancing around or addition of a temperature probe, but it can be done. What you can't do is compensate for an inconsistent grinder. I was able to learn this by eliminating virtually all of the inconsistency of the machine, which revealed that the real problem was the grinder. I feel that I learned this the hard way, and even though the BV was very good, I would have been better off with a K10 right from the start.
My conclusion is that the best approach to espresso is to begin with a truly top-of-the-line grinder, no less than a Super Jolly (Baratza Vario) or better. If you can afford a Titan grinder, get one. If not, start saving for one. You won't regret it. If the grinder breaks your bank, get one of the good entry-level HX machine and a Scace and/or one of Eric's temperature probes. Learn how to get the temperature where you want it. After that, the grinder will take good care of you. If you like milk drinks and can afford a good double boiler machine, go for it. Again, you won't regret it.
Bottom line: my answer to the subject of this thread is: No.
Dick Green
