by cannonfodder on Thu Mar 29, 2007 10:17 pm
There was a thread a year or two ago where we discussed this. I even scrubbed out the chrome on one of my PF's years ago to try it (with the above mentioned scrubby pad and steel wool) and noticed no difference.
However, I do believe you can taste metal and it does taint the espresso, when drinking from a stainless demi. I want to make one clarification here. I believe there is a difference between passing a liquid over a metal (or chrome) portafilter and putting ones lips/tongue on a hunk of metal while drinking. Your tongue/lips are in direct contact with the surface when drinking from a SS cup and you (or at least I) can taste it.
Use the above 'chewing on tin foil' example. If the foil imparted a metallic taint to the food/drink, then wrapping leftovers from dinner in tinfoil would make your chicken taste like tin, but it does not. Now take a bite of that chicken along with a piece of tin foil and chew on both of them. Now you taste metal.
If simply passing water over a metal object tainted the flavor, your espresso machine would have to have plastic plumbing, boiler, grouphead, shower screen, etc. not to mention those steel burrs you just ground that coffee with.
