by boar_d_laze on Sat Nov 12, 2011 11:08 am
It's just a convention, with no intrinsic meaning. Someone or several someones did it one way and it stuck.
Don't let them bully you. You can do it your way if it's easier or has more meaning to you. if you want to share it with other people, call it an "inverse ratio" and let them figure out the reciprocal. Speaking of ratios, I'm comfortable with a ratio expression of "1.4," but not with "140%." There's something so wrong about any percentage greater than 100% (not that it isn't done).
Why do you think you find the mental math of multiplying by 1.4 easier than say dividing by 7 and adjusting the decimal point after doing the calculation? Per part of your hypothetical, 7 into 18 is 2, remainder 4; 7 into 40 is 5, remainder 5; 7 into 50 is 7, remainder 1. 25.7 is too many significant digits, so round up to 26g.
Or, do rough and ready "speed math." For instance, 70% is close to two-thirds, 18g is evenly divisible by 2 (2 x 9), simple inspection gets us to a brew mass of around 27g (3 x 9); but 70% isn't actually 2/3, so round down and call it 26g.
However, our 26g results tell us that your 70% wasn't accurate, even to two significant digits. Let's do some easy, mental long division. Temporarily forget the decimal point, use "place holder zeros" for convenience, and it goes like this: 25 goes into 180, 7 times with a remainder of 5. 25 goes into 50, 2 times. Readjust the decimal point and Ratio = 72%, on the nosey.
Speed math? Easier still. 25 (with the decimal point moved two places) is the reciprocal of 4. Multiplying by 4 will give you the same digits as dividing by 25. 4 x 18 = 72. Voila.
Some people find this easy, some excruciating. Me? I'd be an idiot savant if only I were a savant.
Lots of ways to skin the cat, not to mention the calculator on your phone. If your calculations tend to be inaccurate, that might be best.
BDL
