Confused about definition of "ristretto"
I've heard two things...and it can't be both!
A RISTRETTO SHOT
It either...
Begins with a finer grind, which slows the length of the water passing through the filter basket. Still taking a normal length of time, but producing less volume in the total espresso shot.
OR....
It's a normal grind, but the machine is turned off earlier, creating the short shot that way.
NEITHER ONE SOUNDS TERRIBLY CORRECT NOR APPEALING.
I'm yanking my hair out on this one, because I've searched every reach of the internet and both answers are equally stated. If you could also tell me how much should be in the glass if I am NOT using a 2-way spout. I'd assume that a ristretto would pull a little less than 1.5 ounces (again, whilst not using a 2-way spout). But I could be wrong on that one.
AND EVEN IF....
the short shot measured out to be 1.5 oz, how is it so different from a regular double shot? Obviously, with just .5 ounces missing...
Is it because the grinds are finer? How does that change the taste? Or is it because we turn off the machine earlier? How does one gain anything from that? I feel like you would just loose that yummy blonde finish (My favorite part of the shot).
PLEASE TELL ME!!!!
A RISTRETTO SHOT
It either...
OR....
AND EVEN IF....
PLEASE TELL ME!!!!
- EvanOz85
What the heck dude, chill out.
The first definition is the "correct" one. Grind finer to produce a shorter shot in the same amount of time as a normale.
Sorry that doesn't sound "appealing" to you.
.....a joke?Wiccanrista wrote:that yummy blonde finish (My favorite part of the shot).
Joke how? The last part of the shot is the prettiest <3
And thanks, btw. I hope I will have more responses agreeing with you because the last two baristas I asked said the correct answer was the latter.
- EvanOz85
Grab a sample of just the blonde end and taste it. Report back.Wiccanrista wrote:Joke how? The last part of the shot is the prettiest <3
I would not purchase anything from a shop employing those baristas.Wiccanrista wrote:And thanks, btw. I hope I will have more responses agreeing with you because the last two baristas I asked said the correct answer was the latter.
- keno
Just goes to show that beauty is in the eye of the beholder. I find the beginning of the shot the most beautiful - when it looks like glistening chocolate syrup and not the head on a pint of Guinness. In any case, overall taste is the most important thing. If you like lungos, by all means drink them.Wiccanrista wrote:The last part of the shot is the prettiest <3
PS There was just another thread a few days ago on the definition of a ristretto. You may want to review that: 14 grams in, less than 2 ounces out = espresso or ristretto?
I don't think I've ever tasted only one part of a shot before...
- HB
- Admin
That's called the "test of thirds" and you may find it helpful since manipulation brew parameters shift the taste profile towards/away from the first third, second third, last third. I present this in the video Newbie Introduction to Espresso - Taste Diagnosis.Wiccanrista wrote:I don't think I've ever tasted only one part of a shot before...
As for the rest of your post, I agree with Evan: Relax. Forum exchanges are text-only and lots of !?!? and uppercase are interpreted as yelling. When in doubt, step back for a few minutes before pressing Submit.
As Ryan noted, this is covered in the Guidelines for productive online discussion. Contributors to this thread should review it before posting. Thanks.Wiccanrista wrote:...clearly, the gods of espresso dubbed you the infinite holder of all coffee knowledge and gave you the license to act like a superior jerk to everyone...
- yakster
+1EvanOz85 wrote:The first definition is the "correct" one. Grind finer to produce a shorter shot in the same amount of time as a normale.
-Chris
LMWDP # 272
LMWDP # 272
- EvanOz85
That is my experience as well, but I use a machine with a 53mm portafilter and wasn't sure if it was simply due to that. I guess it's a universal thing then.HB wrote:In my experience, ristretto pour times are a little longer.
