Coffee storage and staling
Postby Ian_G on Wed Jun 22, 2011 10:02 am
I came across a couple of papers on staling. One is by a manufacturer comparing their valve to A.N Other valve manufacturer's valve in terms of oxygen ingress to a sealed bag. This may be important if your roaster uses faulty/cheap valves in their packaging. The second paper takes a scientific approach to staling. Using indices of decay by-products as proxies, they quantify the extent of the staling process using air packed; MAP (modified atmosphere packaging); MAP + refrigeration; and air exposed storage. They also use trained tasters to provide human sensory analysis and in so doing correlate subjective taste experience with decay indices. At least I think that's what they do....
http://www.pacificbag.com/articles/VALV...SSTUDY.pdf
http://www.ftb.com.hr/46/46-442.pdf
Ian_G
Postby another_jim on Wed Jun 22, 2011 5:52 pm
Abstract wrote:Applying a statistical assessment of the results, we found the loss of most volatile compounds from all stored coffee samples, including even those stored under freezing
conditions.
This statement is misleadingly translated. Each packet lost a portion of all their aromatics, but the graphs at the end of the article show that the frozen sample lost about 10% of each aromatic, the nitrogen flushed one about 25%, and the normally sealed and punctured ones about 60%.
This article joins a dozen or so I've read that are looking to find measurements of the important coffee attributes like cherry quality, roast degree, and freshness, by measuring the ratio of two aromatic gasses. The papers use lab GC/MS gear, but a ratio of two gasses can be done cheaply in factories and storage facilities using a pair of specifically designed sensors. The procedure is to correlate ratios with sensory assessments. The 80% correlation coefficient for their freshness ratio translates to an electronic nose picking out the stale sample 8 to 9 times out of 10 from a pair of cups, which is getting into the usable range.
I have yet to hear about any of the proposed electronic noses being put into commercial operation; but the potential return must be good, since the labs keep trying to come up with them.
another_jim
Postby Ian_G on Thu Jun 23, 2011 7:54 am
"The samples stored in a refrigerator preserved their aroma for a longer time, with decreased staling rate. We can therefore confirm the recommendation of Kallio et al. that coffee stored in a freezer be used as an unaltered reference for staling studies."
Although this was already known around here, it's nice to get scientific verification.
"Coffee packed in a modified atmosphere under nitrogen (gas flushing) has a longer shelf life than that packed under air. Flushing with nitrogen prevents reactions of coffee odourants and lipids with oxygen."
and "At the moment of packaging the volume percentage of oxygen was below 1 % in packages with the modified atmosphere"
Not sure to what extent this idea has been debated, but again scientific input helps.
I'm not sure that I could pick out a direct comparison of staling rates between nitrogen flushed at room temperature and air packed at -20c. Clearly nitrogen flushing and freezing represent the best option for preserving freshness.
Ian_G
Postby another_jim on Thu Jun 23, 2011 2:23 pm
Nitrogen flushing is the SOP for all pods and capsules, by Starbucks in those big silver bags, and for the whole bean hopper replacement canisters used by Italians roasters for their bar deliveries. There are always several nitrogen flush packaging machines on display at the SCAA, so I'm guessing it's widely used beyond these obvious cases.
What is instructive is that freezing is simply dismissed as a commercial form of coffee storage despite everyone knowing it virtually eliminates staling. The business strategy of large coffee companies is to "add value." This means mechanically harvesting the coffee at source, and then doing everything in-house, from sorting to roasting to packaging, and to portioning and brewing if they can (the pods and capsules). Under this scenario, picking ripe coffee at origin, sorting it there, freezing to preserve it, grinding and brewing it fresh, etc, do not "add value," since they cannot be done in house.
another_jim
Postby Ian_G on Fri Jun 24, 2011 9:09 am
I've just found a way to create an almost zero oxygen - nitrogen flushed storage system. All you need are airtight containers and oxygen absorption packets. These packets come in various sizes and can absorb from 50 cc up to 2 litres of oxygen. If the container is airtight then they claim they can reduce the oxygen content to 0.01%. So you take all the O2 out and what you're mostly left with is nitrogen and some CO2.
Ian_G
Postby another_jim on Fri Jun 24, 2011 4:40 pm
It's a neat idea; but is it food safe? Don't recall seeing them in packaged foods.
There are practical problems too. A lot of this packaging tech is going into preground single serve items, like pods, capsules, and office coffee. This would have to make the oxygen scavengers insoluble when brewed -- it would exclude the classic preservatives -- tannins and other polyphenol anti-oxidants, because they are soluble. If the coffee is being done by a small roaster, the oxygen scavenger will be exposed to air when it is put in the coffee bag, and whenever the bag is opened by the buyer; it would need to handle that without losing all the reactants (for this, tannins might work).
another_jim
Postby Ian_G on Fri Jun 24, 2011 5:39 pm
There's absolutely no problems with them being food safe, they are used already quite extensively. You're right that they do start to react immediately with air, but from what I read, they are so over spec'd that they'd be plenty of time to affix them to the packaging and still have plenty scavenging activity left in them. But what I was thinking about was for home use. In my own case I just bought a tin of Izzo blend, which was nitrogen flushed. But because its a 1 kilo tin, I needed to divide that up into smaller containers, freeze them and, had I thought of it sooner, I would have bought some oxygen absorbers to put in the containers as well. Maybe roasters might consider using resealable bags, or maybe the consumers should get resealable bags together with a pack of absorbers. Obviously the absorbers need to be kept in airtight conditions prior to use, but that's quite achievable, or so the advertising goes. According to what I've read, it takes about 10 hours to reduce the oxygen content to 1% and after 24 hours oxygen reduces to 0.5%.
It may potentially be a threat to small roasters, because if supermarkets specified oxygen absorption from their coffee suppliers then maybe the freshness argument would be less of an issue.
Ian_G
Postby another_jim on Fri Jun 24, 2011 6:19 pm
Almost all coffee sitting on supermarket shelves has either been nitrogen flushed or vacuum packed for the last 30 years, when the cheap one way valves were first introduced. Packing machines that do this are not much more expensive than those which don't, so the marginal cost of doing it is virtually zero
The article was about a new method of measuring staleness chemically; not about preserving coffee. So it used well known fresh and stale coffee benchmarks to see if the measure correlated with industry standard tasting and packaging experience. It did.
Would supermarket coffees profit from extraordinary measures to keep them fresh?
In many cases, they use coffees that are so bad that they stale them prior to packing, since they taste worse fresh than stale. All in all, peak freshness is not an issue, since they are not selling to people who demand that it tastes great, only that it tastes inoffensive and expectedly coffee-like. I think supermarket coffee is fresh enough for what it is.
However, if you are willing to pay $100 per pound for an auction coffee that cups at 95 points, and just $20 a pound for coffee that cups at 90 points, then even the slightest degradation will ruin its value. In such cases, nothing but fresh roasted will do, and even freezing would be controversial, never mind any other sort of packaging. This is extreme; but it shows that the better the coffee, the more valuable freshness becomes.
Freezing coffee commercially, or other extraordinary measures would make sense if the supply of specialty coffee that needs to be fresh increased enough to make it a regular pantry item. Maybe if enough hedgefunds bought enough 3rd wave roasters, this too shall come to pass. :wink:
another_jim
Postby Ian_G on Sat Jun 25, 2011 6:46 am
another_jim wrote:Almost all coffee sitting on supermarket shelves has either been nitrogen flushed or vacuum packed for the last 30 years, when the cheap one way valves were first introduced..........
...............In many cases, they use coffees that are so bad that they stale them prior to packing, since they taste worse fresh than stale. All in all, peak freshness is not an issue, since they are not selling to people who demand that it tastes great, only that it tastes inoffensive and expectedly coffee-like. I think supermarket coffee is fresh enough for what it is.
I don't follow. Either they pack for freshness or they don't. And are you sure about the nitrogen flushing?I thought from your previous post that only a few companies were involved with this i.e. for pods and capsules, and a very few roasters. And why would you nitrogen flush stale coffee?
Ian_G
Return to Knockbox
