In Jim Schulman's Insanely Long Water FAQ , page 12, Taste Test, references are made to "hardness and alkalinity".
Is "hardness" the same as "Total Hardness" and is "alkalinity" the same as "Calcium Hardness"?
The reason I ask is I was lucky enough to score an Ashland Chemicals test kit used for cooling tower water testing and that is what it references.
I've gone to the effort of installing an Everpure Claris system so I want to make sure I have everything setup properly. Using the the test kit here are my readings:
City Water-
125-130 ppm Total hardness
100 ppm Calcium hardness
7.2 PH (measured using a pool test kit)
Previous to the Everpure Claris I was using RO water with a calcite filter:
6 ppm Total hardness
2 ppm Calcium hardness
6.8 PH (6.8 is as low as the pool test kit goes)
Now with the Everpure Claris set at bypass level 4:
60 ppm Total hardness
40 ppm Calcium hardness
6.8 PH
The hardness titrant I was using was 10 ppm per drop so the readings are really 50-60 and 30-40 ppm.
Drained about .75 liters from the boiler and tested that:
70 ppm Total hardness
7.2 PH
I used the machine for a few weeks on straight city water before I installed the Claris filter and I am guessing the increase in PH may be due to slight scale build up that is being removed (hopefully) by the slightly acidic 6.8 PH water (or maybe more acidic since my pool test kit only goes to 6.
If my assumptions of the terms hardness and alkalinity are correct (with regards to the test kit I am using) then it looks like scaling will not be an issue at bypass level 4. This looks fairly close to the "RO and Tap Water" of Jim's Taste Test on page 12.
Am I correct?
I have increased it now to level 5 and will check it again next weekend.
Your comments please.
...split from Determining Water Hardness (Anyone know German Hardness) by moderator...
