In the course of chatting with Cirqua reps, they recommended to me their AB Formula packets. I was initially pretty uninterested, as the Elektra's really not meant to run off a bottle without a Flojet, and I wasn't all that keen on running it from a bottle with the flush regime and all. So I put it off until I found out about LM USA's little GS3 sale and ordered one of those. I called Cirqua up and bought 20 packets of the AB formula to try with the GS3. Here's how they look:
You simply mix each packet into a gallon of virtually-zero water (distilled/RO), one at a time, mixing the first one thoroughly before mixing in the second one. Supposedly this yields you "WBC Standard water," as in water with the same PH, TDS, hardness, etc. as used at the WBC. It cost me about $25 for the packet of 20, including shipping.
Has anybody else tried these? I'm curious if this "designer water" is even remotely worthwhile. I've been pulling shots today, and so far my impression is "meh." The water does taste slightly better to me by itself, tasting blind against my home-filtered water. The difference is small, but it's a little "cleaner." Doing a side-by-side comparison with espresso is certainly not in the cards, but we'll cup some coffees with the Cirqua water and my home water later this week and see if we can perceive any differences. Anyway, I was just curious to see if there was any other buzz about this stuff out there, as I haven't read much beyond the coffeed discussion of the AB formulator itself.
