Omega, they're called "technical writers", do your part to help the economy and hire one.
JBSmoovee wrote:... I mistakenly put it into a mode that seemed like a calibration setting where I could not escape without an input.
JBSmoovee wrote:I was planning to calibrate it to boiling water temperature just in case. Sounds like the offset feature is a lot easier than doing the proper calibration procedure. Just a shame they can't write a decent manual for it.
JBSmoovee wrote:I thought that barometric pressure was the only factor in determining boiling point, but this reference suggests elevation and barometric are required. Is this correct?
Generally you will have to rely instead on a local weather station to provide you with barometric pressure. Trouble is, they always reference their reading to sea level. So if you are using weather station info, you must add the additional elevation correction to "undo" the adjustment made by NWS to provide you with a sea level referenced value.
