fxstsb wrote:First post! My machine's manual says a cup's brew time should be about 30 seconds. Well that would be one heck of a big cup...
timo888 wrote:If the brew time is too fast, you must refine the grind, if your grinder is capable of it. Getting the grind just right is about 80% of espresso making. A capable grinder is must. Refurbed hand-grinders, excellent but requiring arm power, can be had for < $100. A capable electric grinder costs from $250-$1000.
For people who have incapable grinders (either not quite fine enough, or the steps go from too coarse to too fine with nothing in between), there is a hack: grind too coarsely but overdose the basket and compact the coffee in the basket by tamping with great force. This will at least put you in the general vicinity of a mediocre espresso, or yield a cafe crema that's not too bad.
I do not recommend a heavy tamp, however. The above is an interim solution only.
P.S.There is also the possibility that the brew water is gushing past the coffee or through gaps in the coffee bed, aka "channeling", so that you're not getting an even, thorough extraction. You don't describe the "mouse-tail" so we can't know.
fxstsb wrote:Before we get into grinders I want to fix this time problem.
fxstsb wrote:Before we get into grinders I want to fix this time problem. I could not find a procedure in my documentation. I did some internet searches and came up with some basics. There are two adjustments on the pump.I am looking for an adjustment procedure. So far the slowest water time is with the innermost adjustment all the way in, still not slow enough. 8 oz water in 23 seconds is too fast.
cmelak wrote:Actually, I cannot make it grind any finer since any more adjustment and it will be metal on metal.
cmelak wrote:BTW the equipment is 1 month old and I have fresh beans - maybe I am too old
Psyd wrote:Babbie's rule if Fifteens:
Green beans will be good for fifteen months
Roasted Beans will be good for fifteen days
Ground beans will be good for fifteen minutes
Extracted beans will be good for fifteen seconds.
"Grinders make espresso. Espresso machines just get water hot and push it through the puck."
If the coffee isn't right, and the grinder isn't right, you have no hope of getting the espresso right.
I could probably make a better cuppa with a commercial grinder and a Krups machine than I could the other way around.
Before you start adjusting pump pressure, get good beans and a great grinder. Most everything else will take care of itself.
cmelak wrote:I am having similar problem with Rocky. Actually, I cannot make it grind any finer since any more adjustment and it will be metal on metal.
