by another_jim on Thu Feb 10, 2011 11:55 am
I like the over-engineered dispersion block and group bell used on Elektra/Bezzera/Brasila machines (they are not interchangeable, just the same design). A nice laminar flow through the puck is, as far as I'm concerned, contributory to a good shot. All three companies mate this section to a number of back sections (the section containing the three way valve, gicleurs, and attachment to the rest of the machine) that either bolt directly to the boilers or have thermosyphons for heat. If you are using a steam boiler, I'd go with one of these, and use a needle valve on the thermosyphon like Faema or NS, so you can dial in the head temperature to whatever you like.
If you are going with a double boiler, one of the flooded groups, like LM or Synesso, would be best. However, scrap machines from them cost more than the more common scrap machines from one of the above.
