Anyone Else Noticed How Much...
Postby boar_d_laze on Thu Jun 23, 2011 1:04 pm
Has anyone else noticed how much cleanup is involved?
BDL
boar_d_laze
Postby jonny on Thu Jun 23, 2011 1:46 pm
'tis the nature of food prep. Most of us develop standard routines that best suit our setups so that clean-up is to a minimum. I can do everything from grind to clean-up in under 5 minutes. About once a week I clean the front of the machine and wipe up grounds from my station which takes another 5 minutes. A few things that work well for me is I dose my coffee into the basket with a funnel to make sure 99% of my coffee ends up in the basket, not the counter; I flush my hx into a measuring cup and flush the screen and basket over a Tupperware which are easily dumped into the sink and prevents buildup and more frequent cleaning of the drip tray; and I soak my steam wand between use which makes it wipeable with a paper towel (I don't like keeping a damp cloth because it gets mildewy and nasty with milk). For weekly cleanup I use a mini shop vac. If you find yourself cleaning for more than 25% of the time that you are enjoying your coffee, I think you need to look at how you can adjust for your needs to be more efficient and be able to go to the ball!
jonny
Postby mitch236 on Thu Jun 23, 2011 2:39 pm
I find cleaning my equipment daily very theraputic. Once you get a routine down, it becomes quick but still takes a good 5-10 mins.
mitch236
Postby RAS on Thu Jun 23, 2011 2:55 pm
Richard,
Are you only referring to the clean-up time after roasting, or the whole "coffee-thing" (when it's taken to the level we all do)? For roasting, my clean-up takes less than two minutes. I've got quite the routine in general - set-up takes a couple minutes, roasting takes 11-15 minutes (for a pound which yields maybe 14 ounces of roasted coffee), then my two minutes of tear-down.
One reason why clean-up is a snap is that I heat-gun roast outside in a place where once my beans are cool, I use my cooling fan to blow away any chaff I've created, and I'm done.
As others have noted, roasting is just a therapeutic process for me. But I am glad I only need to roast once a week!
Bob
RAS
Postby jonny on Thu Jun 23, 2011 3:32 pm
Woops! Did not notice what section this post was in. As far as roasting goes, yes outside makes cleanup a snap. If I roast indoors, again a shop vac does wonders.
...moved from Home Roasting to Knockbox by moderator...
jonny
Return to Knockbox
