I'm just the final user, but you are lucky
You are right, if we know that Pressure x Volume = K x Temperature , we should imagine that there is a drop pressure when the volume increase.
But.. in the meantime there is an increase in the temperature due to the heater still on (in my case the flame).
I've seen a technical report which says that you have a variable pressure from 9.9 to 9.5 before opening the valve , and during the extraction the machine mantain the 8.5 pressure.
If you want more technical info, i will send you via pm mr. Bacchi email (you can easily find it on the web).
regards
Lucio
