5-speed espresso tamper
- coffeedude55
I had a 5-spd car shifter knob, off my old Firebird, just collecting dust. I had it custom made a few years ago by EPCOmfg. They did it in a pearl white, which has turned to a nice silver over time. They also manufacture billiard balls & bowling balls.
I wondered if I could combine it with my Rattleware 58mm tamper with the shifter knob? I unscrewed the tamper handle, and it measured about 3/4" or 19mm in outside diameter? The shifter ball has a 16mm threaded insert. I went to the hardware store and could not find any bolts that would fit, then I tried the plumbing dept. They had a (Watts A-387 1/2 in. x 1/2 in. Plastic Barb x Male Adapter (15mm x 15mm) threaded nylon hose barb). I thought it might work. I had to cut, grind, and sand down the threaded part, but it did fit with a little effort. The barbed end was a little too thin, so I gave it a good wrap with Teflon tape.
This was an easy project, and came out pretty good. It has a nice look and feel. The 2" diameter works good for this application. It's about 1/4" larger in diameter vs. the Rattleware handle, but it doesn't feel oversized.
Photos: http://www.flickr.com/photos/102043207@ ... 838791195/
- UltramaticOrange
I couldn't use that. My left foot would be stomping on the floor looking for the clutch every time I pulled a shot.
If your tiny coffee is so great, then why don't you drink more of it?
twice per tamp...UltramaticOrange wrote:I couldn't use that. My left foot would be stomping on the floor looking for the clutch every time I pulled a shot.
- beta14ok
- LaDan
Once you've gone through all the gear shifts, your puck is perfectly nutated.
- old442
Thankfully that wasn't from an old Mopar with the pistol grip, it would not be very ergonmic.
Kurt
LMWDP 114
LMWDP 114
- UltramaticOrange
Pistol grip ... pulling a shot ...
