oconee wrote:A few of the contestents in the roast competition used Behmor's and provided some comments on the batch size they settled on. I found that interesting reading.
In my Behmor, I normally dose 250 - 300 grams for 1# roast settings. I tend toward 250 gram batches for coffees that I'm trying to emphasize brightness and fruit on. I also recently roasted up four Dominican Republic coffee samples from Theta Ridge and used ~180 gram doses on 1/2# P3 A roast profiles which I think worked pretty well. I'd culled 200 gram samples and roasted the nice beans that remained.
I do pre-heat the Behmor for two minutes with the chaff tray installed (and drum out, waiting with loaded greens) which results in a drop-in temp of about 200 degrees F. The ET in the roaster hits upwards of 280, but when I shut down the roaster, quickly open the door and pull out the old-style chaff tray with my Ove Gloved hands and put in the drum and start up with my desired profile, it's dropped down. Any longer than two minutes (it varies depending on the particular Behmor) and you risk being unable to re-start the roaster due to the control circuit preventing a restart over a certain temperature.
With the Behmor, there is a gradual ramp up to temp that corresponds to the drying phase of the beans. I feel you want to tweak your load size so that that ramp works well for the drying phase and then I compensate for the roaster's tendency to roll from first crack right into second by cracking the door a bit (sometimes propping it open with a metal tweezers I use for culling beans) while monitoring the ET temperature with a Thermocouple and RoasterThing software.
After reading the
Scandinavian style thread, I've begun to slow the roast right when the greens hit full yellow, well before first crack, to emphasize the sweetness and then when first crack hits I'll drop the temp even further and stretch out first. The more gentle P3 profile with the DR beans seemed to match the lower temp during full yellow pretty well with the batch size I picked. It's also more appropriate for a lower-grown island bean.
