Arpi wrote:Hi all.
I just did a roast with wood chips in the beans. I have several wood types but the mildest ones I have are alder and apple. So I did a roast with 4 small chips of apple wood in the beans (~300 grams) of Ethiopian Harrar. At dry-end the wood chips already give out a lot of smoke (probably humidity). I thought it caught on fire, but it wasn't smoke fire. I'll give a try and if it is something I like. I'll also try with alder wood. I will also use maybe 2 chips instead of 4 if the flavor comes out very strong. I was surprise to see all the smoke come out of the exhaust pipe for only 4 small chips!
Cheers
germantown rob wrote:Unlike smoking foods the smoke is not really going to be absorbed by the bean but leave some flavor on the outside of the beans. Make sure you do some extra cleaning to your quest, I can say that my smoker gets very coated from the resins. A thought I had is putting chips in the roaster may not be the best method to get smoke to the beans, maybe there is a way to use your heat gun method to blow smoke in with the wood already combusting.
