by Randy G. on Fri Sep 12, 2008 4:33 pm
What was the line voltage to begin with. iirc, anything over about 112 and the Hottop (at least the more recent versions) does not really need a variac.
Interesting that you ask this just now.. The local electrical utility service person just about an hour ago. He was here because.....
I recently bought a Kill-A-Watt meter off eBay. I wanted it to be able to judge things like... coincidentally enough, the wattage drawn by the Hottop B to see how it was controlling heating element levels. I plugged it in, and was a bit surprised to see the voltage on my line. For years, every time I measured it, it read 122 volts without a load, +/- a few tenths. The Kill-A-Watt showed 128.5 +/-. "Wow! That's a lot of volts," I thought to myself. I figured that there was something wrong with the Kill-A-Watt, so I whipped out my Fluke voltmeter, and it showed the same, within abut 0.5 volts.
I was a bit concerned about my appliances, and a bit paranoid because we once we had a problem with our underground cable after the phone people drove a ground rod through on side of it. We were getting about 140 volts on one side and 90 on the other. The lights in the kitchen were really bright, though!
[and just in the middle of that last paragraph the electricity for the whole house went off! Thanks to a UPS, I saved what I had typed and shut down... I immediately called the utility's outage phone message line to report it, and the recording said they were aware of the difficulty which started one hour earlier {!}.]
As soon as the electricity came back on, I plugged in the Kill-A-Watt, and what do you know!? 121 volts!
I wonder how long it was too high, and I wonder to what extent it shortened the life of some of my appliances...?
