There's too many variables to explore successfully. So my current practice is very simplified - I run a nearly constant MET between 250C and 260C (480F to 500F), which is as tight as I can get the control. If I want to roast slowly, I run at low heat and low airflow, if I want to roast fast, I run it at high heat and high airflow, but always at this MET
So now I dry very low heat and air, ramp to the first at max heat and air, and finish at medium heat and air, twiddling the fan to keep the temperature around 260C.
I do not know if this technique carries over to other Probat style roasters, or if this is peculiar to the Quest. If this technique holds up for me, I'll PID the heater to the MET, and will control the roast speed by twiddling the air knob.
