by scrutinizer on Fri Jul 23, 2010 8:14 pm
Phillip,
One way to get the Behmor (w/ mostly fixed profiles) to perform in a manner that approximates the more commonly used timing (e.g., 1 C around 10 to 12 minutes and 2C about 4 to 6 minutes later) would be to use the P2 setting (3 stage profile with heating at 100%, 70%, 100%) and select a bean load and roast time (A, B, C) to position the beginning of drop in heating at the end of 1C (i.e., 1C finishes, THEN the heat drops to avoid moving quickly into 2C). Given that 1C normally takes about 1.5 minutes, this translates to shooting for the start of 1C to occur at 10.5 minutes elapsed (1 lb P2 B profile drops the heating at 12:00 minutes elapsed) or start 1C at 11.5 minutes elapsed (1lb P2 C profile drops the heating at about 13:00 minutes elapsed). I recommend having the heat drop after 1C is mostly complete (this is different than the common wisdom) because from my experience the 70% heating on this roaster may not be sufficient to sustain 1C without stalling the roast. In most cases, you will stop the roast before the last 100% heating leg occurs so really this is a 2 stage profile with full heat through 1C and reduced heat until the end of the roast. You could experiment with some cautious door opening once 1C begins to try and slow the pace while the heater is on 100% which is more than is needed. A window of bean loads to start with would be in the range of 8 to 12 oz (i.e., approx 8 to 10 for "B" and 10 to 12 for "C" but YMMV).
Of course the timing of the roast given a fixed profile will change with all the other variables (bean type, power, ambient temp, humidity etc) and so getting consistent results with this approach can be frustrating to get the hang of but it can produce very good results if you nail it and over time its not that difficult. I find I get more consistent results on the timing consistency from batch to batch with pre-roast blended espresso blends as the effect of each bean origin on the timing of the roast is more muted with a blend relative to single origin batches. Thus, I can usually modify the blend somewhat to try different options without dramatically changing the roast time.
Good luck,
Pat
