I presumably "cupped" the thing and my question is now the following: is there such a thing as "ashy bitterness that is caused by the fines suspended in the liquor"? If there weren't such a thing then the liquor I got should have been bitter, otherwise I don't think that the liquor has been either inherently bitter, sour or anything else, i.e., I think that it had a presumably "clean" taste. A brief summary of the situation is that I am not being able to interpret what I have tasted (either positive or negative) due to me lacking any experience in "cupping". Note that I am totally neutral and unbiased to either conclusion. I also tasted the coffee next to pineapples and found the taste acceptable except for the ashy bitterness. I tried both of my Zassenhaus Turkish grinder and the other hand grinder for the cupping and noticed that the ashy bitterness may be resulting from the fines. I have another hand grinder that doesn't produce any fines but the problem with it is that the grind is very coarse (maximum particle diameter around 5mm, average around 1.5mm, very coarse), which I have not used. Using this grinder I am usually able to produce a liquor that is light in colour (tea-like) with a clean taste, but I did not use it this time because I depleted all of the 15 grams I roasted using the other two grinders (using 8 grams for 245 ml of water at a time). I am sorry if I am providing an excessive amount of detail but obviously it's because I have no experience and happens to be in a position where I need to carry on a test that I don't know how to conduct.
I am a little embarrassed to add that I went through another horrible roast in which I stayed at 180C for 10 minutes before ramping up to 200C and staying there for some time, then ramping up to 205C and ending the roast. I would like to confirm that the beans don't pop in such circumstances and that the acrid, ammonia-like acidity gets removed completely with no choking aftertaste in this case (this roast was 26 minutes in total). Note that I used a fan speed of "2" for the length of the ten minutes I spent at 180C. The interesting observation at this time was that the droplets of condensed roasting vapour had an intense, ammonia-like acidic smell that matches very well the defect that I have been trying to eliminate in the taste (same smell I used to experience upon opening the door of the oven when I was roasting using ovens). I think that this means that the substances responsible of the acrid acidity have been dissolved and carried away by the confined, moist roasting vapours. Of course, I do not want to be a lousy roaster and be proud of it, but I cannot resist proposing the following theory: Could it be that the chlorogenic acids (melting point: 206C-210C, some are soluble in hot water) are getting hydrolysed due to the circulating, moist roasting vapours resulting in quinic acid (melting point: 166C-168C, water soluble) which is then being dissolved and carried by the moist vapours -thus getting removed from the beans? (quote: "Quinic acid is also implicated in the perceived acidity of coffee", says Wikipedia). Now assuming this fairy tale was correct, then an extended drying phase at 338F (or maybe less) with a moist roasting environment may do the trick. In either case, I did not succeed in removing the acidity in temperatures below 300F and so I would like to humbly state that I don't think that the removal of the acrid acidity is correlated with raising the temperature beyond 390F or prolonged drying below 300F (not having these as direct cause). My speculations of the underlying transformations are probably incorrect, but this must not be confused with the fact that I am having great success eliminating the acrid acidity using some baking-based methods.
another_jim wrote:A US home roasting "tradition" is to come up with ever more appalling roast practices in response to using lousy coffee, never cupped or even brewed, for espresso. This is another tradition worth avoiding.
Not anymore! It seems as if it were a Saudi-Arabian tradition as well
