Warning! North TJ-067 (late 2013) Fasteners Get Loose in Cooling Tray
- drgary
Note: This is about a North TJ-067 just before Mill City took on U.S. distribution.
Hi Everyone:
I noticed something shiny before it went into my grinder. Then I discovered that there's an inherent hazard in my North TJ-067 cooling tray. The arms have thick Teflon strips attached by 10mm hex key screws with nuts fastened into the Teflon. The folks at North probably thought the Teflon is good to tighten against because it creates a snug fit -- except that plastic migrates over time. One of those nuts loosened and almost ruined my Ditting burrs! I've just added threadlocker to those nuts and will keep an eye on them from now on. I've cross-posted this to the North Roaster forum to make sure the word gets out!
Here's a close-up
Fastener with hex key inserted
Hi Everyone:
Here's a close-up
LMWDP#308
LMWDP#308
They should probably just use Nylocks instead of loctite so it's obvious they need to be locked.
Ira
Ira
- Randy G.
+1ira wrote:They should probably just use Nylocks instead of loctite so it's obvious they need to be locked.
- drgary (original poster)
Thanks, Steve. I noted my early version above. What's the other side of your fix look like?
LMWDP#308
LMWDP#308
- millcityroasters
Pretty much the same socket head cap screw. Just replace the slippery nuts with Nylocs. They are metric but I don't recall the size. Maybe M6?
They take a 10mm wrench, so yes, that's M6.
LMWDP#308
LMWDP#308
Nylocks are really only useful if the bolt extends at least one thread past the nut. You need to use a longer bolt.
Ira
Ira
Thanks, Ira. I've applied thread locker and have nylocks on order. The threads extend well beyond the original nuts. I'll see if they fit. But you're correct about the photo shown by Steve. The threads don't extend beyond the bolt there.
LMWDP#308
LMWDP#308
- Balthazar_B
I'm sure Steve will reply and clarify as soon as he's finished loading up the fireplace with a few oak logs, but I'm guessing he showed the nut without a bolt to illustrate that they're using Nylocks. Of course, if they're not extending the bolt a thread or two beyond the end of the nut, that can be very easily remedied.
- John
LMWDP # 577
LMWDP # 577
