US Roaster 3k warm up time
I recently had the opportunity to upgrade my USR Sample roaster to a used 3k roaster at a price I could not resist. The previous owner operated the machine on nat. gas, so I had to convert to propane. The learning curve is steeper than I expected, but I am still trying to determine how high maximum gas pressure should be. (the machine has an adjustable controller). If I use the max. pressure the controller will allow, I get a fairly rich gas mix and see more yellow flame than I would like and get soot on the drum.
So, in order to get some idea of a benchmark from any users of the same roaster, how long does it take to warm up a cold machine to @ 350°F? Or, what RoR is reasonable for an empty machine?
- cimarronEric
- Sponsor
It sounds like your propane conversion didn't come out right to me if you're too rich. I am on propane and can crank it all the way and still get a pretty clean blue flame and definitely no soot on the drum. Did you order the kit from USRC?
As far as pre-heating. I heat on 1/3 full pressure to try to instill a bit of thermal mass, rather than get 350° ASAP. It takes ~15 minutes to get to usable heat.
Cimarron Coffee Roasters
www.cimarronroasters.com
I was hoping you would answer. Yes, I am getting help from USRC and used their kit. My machine does not have a pressure gauge installed, so that may be an issue, but it's the same hook-up I used with my sample roaster with no problems.
I just don't know how much yellow is "normal". I may try to clean the burner jets with a small wire, as only some of the jets are yellow at the tips. You answered my bigger question about time to warm - I agree that I don't want to race to warm as there is a lot of mass to bring to temp. I'm in that 15 min range at about 40% gas.
I am amazed at how much difference the damper at the feed chamber makes in ET rate. The air adjustment is the biggest difference I've found so far.
- cimarronEric
- Sponsor
I'm running air by rheostat only so I can't speak to the damper adjustment. I do keep my air changes to a minimum using minimal air for most of dry and ramp and ~full air from 1C to dump.Ol'Timer wrote:I am amazed at how much difference the damper at the feed chamber makes in ET rate. The air adjustment is the biggest difference I've found so far.
I agree with your comment about how much difference a change in damper can have. I'm finding if the flame is at the right setting, fine control with the damper is very effective.
