AndyS wrote:Maybe this?
Thanks Andy. When it comes to Carl Staub vs. Kenneth Davids, sorry Kenneth, but Carl is the man.
Fullsack wrote:Thanks Andy. When it comes to Carl Staub vs. Kenneth Davids, sorry Kenneth, but Carl is the man.
Re: Cooling too quickly
by Andy Schecter on Tue Jun 06, 2006 4:07 pm
JIm wrote:
I know you can cool a roast too slowly, but can you mess it up the other way around?
I asked Carl Staub about this at the SCAA show in Atlanta. He said:
1. If the cooling is too slow, skunky odors will develop.
2. 3-4 minutes to room temperature is ideal.
3. Too fast a cooling cycle will disrupt the cell structure (producing widespread micro-cracks) and cause staling to occur more quickly.
TUS172 wrote:Is this what you were referring to Doug?
scottfsmith wrote:Bob that looks like a great setup. I believe the fan model # is HWL HT-800? The setup I use has the same top (colander in bucket), but in the side of the bottom I cut out a hole in which I insert my shop-vac hose and I use it in suction mode (I am traveling now so cannot add a picture). My setup cools in 3-4 minutes but it doesn't get rid of the chaff. Also I have had problems with the vac hose getting too hot. I am going to try my setup in blow instead of suck mode next time to see if that will de-chaff the beans, and if that doesn't work I may get one of those Honeywell fans.
Scott
Theodore wrote:Having the bucket above,and a Miele 900W vac,now in summer,I have a issue with the vac,which stops working,because of high temp motor protection.
In winter,I had not issues.
Any suggestion?
