Randy G. wrote:
- Replace the rear filter. DONE
- Clean the temperature sensor inside the roasting chamber. DONE
- Disassemble and clean the entire roaster. DONE
- Be sure all internal connections are tight and clean. Disconnect and reconnect everything you can get to. One connection that can be problematic are the two spade terminals at the back of the temperature sensor. DID SOME, NOT ALL
- Be sure the black filter on the top of the machine (behind the top grill) is in place. DONE
- Remove and check the rear fan. As coffee particles and oils build up on the blades it dramatically decreases its efficiency. DONE
- Check the voltage at the outlet you are using, or try another outlet on a different circuit. TRIED ROASTER AT 3 DIFFERENT HOMES
- Try programming it for the max time and temperature possible and running a roast with no beans to see if it reaches the correct temperatures. SEE BELOW
I eventually gave up on the roaster after trying several suggestions, including those above and some by HottopUSA. I had a great local roaster nearby and have been buying beans since. Now I have moved however and getting good beans is more difficult. I need to get the Hottop up and running again!
In addition to the above I also made sure to align the heating element parallel to the drum. I also made sure there were no scratching / parts touching as the drum rotated.
I ordered a fresh batch of greens which roasted yesterday. I programmed the machine to the highest target temperature for each segment. In addition I shortened the time within some segments to try to ramp up the temperature as quickly as possible.
I used 250 grams of Sweet Marias Monkey Blend. The total length of the program was 15 mins 30 seconds. At the end I added 30 seconds for a total roast time of 16 minutes. I have attached a picture of the roast temperature at the end of each segment (in addition I recorded a temperature of 201 degrees C with 4 minutes left on the timer, not sure how important the sampling rate of data is here...).
First crack started with 02:35 left on the timer, approx 207 degrees
First cracked slowed down with 01:07 left on timer, 213 degrees
Second crack started with 00:50 left on timer, 216 degrees.
I ejected the beans after adding 30 seconds (1 minute 20 seconds after second crack started). Temperature was 219 degrees.
None of the cracks really took off though, especially the second one since I ran it that far into second crack it should have been really popping! There was no visible oil on the surface after 24 hours. The beans had a wrinkled finish and they don't smell like a good roast should.
