by DJR on Wed Sep 14, 2011 1:44 pm
Dave or anyone else,
Do you end your roast "by the numbers"? Currently I use an IR hand held thermometer, but really only use it to monitor and control (manually) heat rise. I know it is not accurate, but it does tell me when the bean mass is getting hotter. I kind of do a mental average, since it can be plus or minus 15 degrees. I shoot 3-4 times and so it's not a problem. If the rate of heat rise is too slow, I increase the propane and vice versa.
What I want to get is a measurement that will tell me what I'm guessing at right now:
When to pull the beans right before they go into 2d crack?.
I was thinking if I found a temperature and it was repeatable (accurate is important, repeatable is) it might help.
Any suggestions/advice on this matter?
Thanks
dan
