Some ET and drum temperature correlations. Mini 500, Yirg DP G3 from SweetMaria's. 300g. Drum temp measured by a Fluke IR thermometer.
Batch 1. First batch of the day. Charge temperature 20c higher.
Time/Temp/Drum/Heat/Vent
0:00/160c/246c/0/1
1:30/98c/209c/110/1 Turning point
6:50/150c/230c/160/3.5 Drying finishes
/188c/247c/50/3.5 Heat down in anticipation of first crack
10:50/191c/50/3.5 First crack
13:00/202c/243c Drop
Batch 2. Charge temp 140c, 20c lower than the first batch.
0:00/140c/180c/0/1
1:30/98.7c/173c/110/1 Turning point. Notice ET and drum temp are different compared to the first batch
7:42/150c/234c/160/3.5 Drying finishes. Notice similar temp compared to Batch 1.
/188c/250c/50/3.5 Heat down in anticipation of first crack
11:19/191c/50/3.5 First crack
13:19/203c/229c Drop. Notice the ET is similar to batch 1, but the drum temp difference
Batch 3. Charge temp 140c, but vent was minimally open to decrease convection.
0:00/140c/194c/0/1
1:30/88c/184c/110/1 Turning point. ET and drum temp compared to Batch 2.
7:42/150c/220c/160/3.5 Vent open for one minute, then minimally open to decrease convection
188c/246c/50/1 Heat down in anticipation of first crack
13:10/193c/50/3.5 First crack. Note it takes longer to reach first crack when convection is decreased. The temperature is also 2c higher. Vent open to decrease smoke particles.
15:25/206.9c/229c Drop
The three batches differed in time from start of first crack to drop by about 10-15 seconds (2:10, 2:00, and 2:15). The final roast color is similar, at least I cannot distinguish, but the bean volumes/expansions are significantly different.
I generally find it easier to concentrate on just one temperature, ET or BT. The drum temperature is too sporadic, as it differs by convection.
