allon wrote:I have some ready for the grinder tomorrow.
Jaholliday- maybe try adjusting the dose? What are you dosing now?
I'm using a triple basket in my bottomless portafilter - around 22g. Might try dropping that and going a little finer on the grind. It's very strange and something that I've never run into before. The shots taste pretty good so maybe it's just too much information with the bottomless. That said, the last couple shots I pulled took about 10 seconds to get going from the time I turned on the pump, and then at about 20 seconds began flowing much faster than normal. I'm getting 60ml in about 30 seconds, so not so far off the mark. Just a big weird how it goes from nearly choking to a quasi-gusher.
Perhaps I need to rest it a little longer? The first shots I pulled were around 4 days post-roast, but the beans I'm using are gradually getting 'younger' since I've been pulling a lot of shots trying to get it right (and hence running out of rested beans).
I took the roast I did today a little farther - more like FC - so we'll see if that helps.
