by randytsuch on Thu Dec 03, 2009 2:12 pm
One thing I forgot to mention, I use a soup can for the chimney, and I wrapped the can with a layer of Melamine foam, held on with tie wraps.
My reason for insulating was to try to create a roasting environment with a more consistent temperature in the chamber. The less heat loss in the chamber, the more consistent the temp in the chamber will be, and you should get a more even roast, at least that was my reasoning for adding insulation.
As long as you can control the heat, you don't have to worry about going too fast.
One other benefit to insulation. I can grab the soup can, or my pumper right after I finish the roast, to dump the beans, and I don't have to worry about anything being too hot, and burning myself. The pumper is warm, but not even close to being hot.
Randy
