samgiles wrote:They roasted as I would expect and I dropped them just as they were entering 2nd crack. All was fine. Then I tried to use them and found that water would just run through. The grinder was, at that time, dialed in for Ethiopian Harrar beans I had been using from my usual supplier. So I tightened the grind. I ended going 6 notches tighter on the Major just to slow the flow down! Even then I got no crema and every shot I've pulled with this bean, at any grind, has been undrinkable.
What about your other roast parameters? Like total time, and time between segments? It may be a shot in the dark (as it was for me then), but I've had several fruit-bomb naturals (Panama Elida most recently) that seemed to behave well outside my accustomed envelope. I suffered many trial roasts and many over-bright, grassy, harsh, underdeveloped shots, even when bean color was not aggressively pale. To oversimplify, I basically settled on roasting longer and slower, ending probably a couple of minutes before 2nd, using the balance of tartness vs. roastiness in the cup to determine my preferred end temperature. This treatment would BAKE most of my other beans, but here it delivered sweetness, aromatic tangy fruit, syrupy body and decent crema without the nasties. The best shots came ristretto-style: ground finer, dosed higher, and extracted longer, despite which, they seemed immune to bitterness.
On the age issue, my experience, FWIW, with older beans is one of increasingly muted flavors: less of the good stuff, but not more (or new) bad stuff. They just got boring and generic.
