cfsheridan wrote:The first roast (unless you did a pre-heat for a full or nearly a full cycle) will be different. For back-to-back roasts with a pre-heated roaster, with the same starting parameters, the hottop runs dead on (or as close as a manually controlled roaster will run). I've done 10-20 back-to-back roasts with the same origin (country, not estate), and had roast results (drying, 1st crack, end of roast, mass loss) practically the same. Did 20 roasts of 230g start mass, using the same profile, with end mass within 2-3g across all the roasts, using a scale that measured to the nearest gram.
The hottop is a very consistent roaster, in my experience.
I would not overestimate the significance of getting the same final roasted bean weight after repeated roasts. I always use 454g charge weights in my 1lb sample roaster (that a long time ago I used to roast 500g batches in, but that is ancient history at this point), and I weigh each batch after roasting on an accurate electronic gram scale. In spite of what can be fairly obvious differences in profile among batches, as long as I go to the same final temperature my batch weights are nearly always within a gram of each other, for a given coffee roasted to the same final temperature. I do try very hard to roast consistently, however my roaster is 100% manually controlled and as the roasting session drags on the drum stores more and more heat, plus, the ambient temperature in my garage can change, especially in the winter. I tend to roast at least 2lbs of a given coffee each roasting session, and often as many as 5, all of which get blended together (for a given varietal), which cuts down on the variability from roasting session to roasting session.
Each coffee is different and seemingly similar coffees often will have different end weights, when roasted to the same final temperature with an essentially identical profile. It is usual, however, for a given coffee to have all its final roast batches weigh within a gram of each other, and this is starting with about 2x as much coffee as you are starting with, e.g. 454g.
I'm not saying you shouldn't weigh your coffee; you should. It provides an important data point, and for free. I would not, however, over-interpret nearly identical batch to batch final weights as indicating total consistency on the part of the roaster. I do not think that this is the case.
ken
