MaKoMo wrote:Then I tested all three as SO shots and observed that I needed to adjust my grinder for each of those SO to achieve optimal extraction and taste.
Absolutely yes. Within the context of a SO, it is not surprising that grinder adjustments would be necessary. To further confound the issue, grinder adjustments may be made across the usable life of the roasted coffee. There are equipment differences - flat vs. conical burr grinders, lever vs. pump, the list of considerations can be staggering from a roaster's perspective.
Isn't taste be connected to grinding and especially particle distribution and as such also to bean density and its variation within a blend?
If the batch were placed into a container and then agitated with enough force to promote movement for enough time, it stands to reason that the denser beans would migrate toward the bottom, altering the physical composition. If the batch were then loaded into a grinder, there would certainly be differences in consecutive shots. The grinder, if not adjusted, would play a part in this as well. Still, that's a lot of
ifs.
I have only anecdotal evidence that commercial roasters roast to their equipment; that is, they are using a specific grinder and machine, so they tune the roast and blend to those machines. To account for different types of equipment would be a rather large undertaking. Still, there are roasters that do this. I think that one of our members here, romanleal - a commercial roaster himself and one of the guys behind Evocation Coffee - has put out a "49mm" blend tuned for lever espresso machines. During the last Chicago Get-together, we had a chance to briefly talk about it, and he mentioned that testing was done on his La Pavoni.
My approach to blending considers taste as SO to be the primary influence for component selection. Mixing fewer components is a strategy to minimize the possibility of flavor differences due to less of A, more of B that is ground for a given shot. I have been able to access identifiable basic flavors (stronger acidity from a lighter roasted accent, good body and caramel base from the darker roast) in batches of up to 300g without considering bean density thus far, and in sampling the batches I have found that the rough percentages hold up.
In practice, I haven't found density to be of any significant influence with regard to bean selection. I can taste the components, and that is an acceptable level of precision at this point. I can hit the broad side of a barn more often than not
Based on your earlier post, have you found this to be consistent with your experiences, or is there a significant difference?
Your dog wants espresso.
LMWDP #288
