Show your home roasting setup! - Page 5
- Quoddy
Quest M3 using: Amprobe TMD-56 datalogger, Omega K probes, Artisan software on MacBook Pro.
ET/MET probe is through a drilled M4 bolt holding the upper right portion of the bean chute. Currently BT probe is in the "standard location" below the trier through a drilled M8 bolt, but I'm planning on installing a short probe through the left M4 bolt of the viewing window.
There is no such thing as strong coffee, only weak people
I love all the high tech setups! Here is my humble method.
I have a cardboard box/strainer setup that I devised for cooling now, it works very well.
Roasting in the dark, before the wife and kiddos wake up.
Not one of my better roasts. I overdid the heat and ended up with some blowouts. I've gotten much better over the last couple months.
- jamoke
- Quoddy
I have an almost identical window type and position. I cut, painted, and screwed a piece of plywood the identical width of the opening side of the window and just wide enough to stand a fan on. About 5 minutes into the first batch I open the window and turn on the fan.Hotep wrote:Would like to devise a mechanism to blow smoke out the available window.
<image>
- sversimo
I envy you that can roast in your own home, its not the same feeling when you got to do it in the workshop... heres my workshop setup;
- yakster
Nice roaster, I like the trier and all the controls, and I have to say I'm a bit envious of your workshop.
That roast looked pretty light, what were you roasting and how did it turn out?
-Chris
LMWDP # 272
LMWDP # 272
- sversimo
Thank you!
I roasted Kenya Nyeri Gaturiri PB from sweetmarias, it was about as low as you can go with this coffee, perhaps I will roast it a few seconds more next time, but I like my roasts light.
- FotonDrv
There sure are a wide variety of roaster represented in the Thread!
I was considering the Behmor and have participated in roasting on one a couple of times, but there was fiddling around with the door to help the cooling cycle.
I have also noticed that folks have modified their Hottops so they work better. The Quest Mods seem to be for monitoring, or have I missed something.
Diedrich has a nice machine and they USED to have a small home model, the HR-1, but no longer make it and instead are selling a slightly larger machine. They are also working on a 220v all electric machine with I think is going to be in the 1 kilo capacity range.
The Huky 500 needs an external heat source.
So which one of these roasters are going to be the end all roaster for us coffee addicts?
- drgary
Probably something like a Mini500 at a lower price point.FotonDrv wrote:So which one of these roasters are going to be the end all roaster for us coffee addicts?
LMWDP#308
LMWDP#308
