Roasting profiles for Decaf & Regular with a Behmor - Page 3
Postby trix on Sun Aug 17, 2008 11:16 am
We are also in FL. We started out buying our green beans from CCM - picking up the orders...but the last few times we've bought from Kevin at Theta Ridge Coffee in Indiana. He has better prices even with the shipping, I think, and he also carries Daterra.
Oh, and I had the same problem when I attempted to post a photo earlier in the week.
Lucy
LMWDP #166
trix
Postby shakin_jake on Sun Aug 17, 2008 12:40 pm
Hi Lucy, I'm not a skilled computer operator. I'm better at making coffee than PC's and I'm a coffee n00b at that=:-) I'm using Vista so if anyone has some recommendations on how I can re-size the photo, I'd be happy to post it
Jake
Reddick Fla.
shakin_jake
Postby IMAWriter on Sun Aug 17, 2008 1:23 pm
Jake...P2 can be tricky...smaller loads may work better. 12 oz @1# setting, etc
I am concerned that you're not getting to 1st crack by at least 14 minutes into the roast. Something doesn't sound right.
I want you to start your roaster by hitting the "Cool" button....wait 20-30 seconds, then bend down, and look up to the top of the roaster. Is the "after burner" working? (it should be glowing)
If it is, then THAT'S not the problem.
If you have a Costco or Sam's club around, see if you can get the "Tripplite" Battery backup/surge protection. It has a blue led that shows you what your voltage is at the source, and what you are losing as the machine runs. It's a power conditioner as well, and will attempt to somewhat correct the voltage upwards.
Are you certain the machine is clean back by the temp sensor? (check at the Behmor website for a diagram as to where it is. Most important.
If you are using SM's (or another reputable bean source) green, that is also not the problem.
Try your Guats and Centrals on P1...or did I say that already?...LOL
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby shakin_jake on Thu Aug 21, 2008 3:44 am
Hey Rob, I would have gotten back with you before this but i've been kinda busy with Fay, watching, getting things organized, put away. Anyways, I don't think I have a problem with the Behmor not working properly. No, I didn't do your cooling cycle check but i do have a voltmeter, several in fact (multimeters) and the voltage at the outlet is good(124.6)
I probably misspoke about the time 1st crack started. I surely got through 1st crack by the time the 1 lb P/2 B roast was through. I drank all that coffee and it was very good and has given me pause to drink more roast profile type espresso blends, at least in the near future
I was working around in the garage that day and may have missed 1st crack and what I wrote down hearing with 1 minute on the clock, could have been the end of first crack and not the beginning. As you know, on this setting, the roast sort of rolls into and out of 1 st crack, and 2nd crack as far as that goes, unlike when roasting on the 1 lb default cycle where you know what what is happening as the temp is the same (more or less) all the way through the roast, so no surprises
Anyways, I roasted a pound of Papau New Guinea yesterday afternoon on the 1-P/2 B setting, added 30 seconds at the end and was rewarded with a roast that looks to have reached full city. I did it up Wednesday around 5 PM IIRC and have not had a chance to taste it yet. I will tomorrow as i don't have any other fresh beans to grind and drink= : - ), but read some verbiage the bean seller wrote where this coffee likes a full city + and 3 days rest. We'll see what jake thinks <LOL>
the way I'm thinking, whatever bean I'm going to order next, and whoever I get the bean from, I'm getting 5 pounds and will play with this same roaster profile, probably only changing the length of roast time at the end, at least that is the way i'm leaning at the moment
In regards to trying the central beans on P1, I could do that but I really want to explore the 1-P/2 B profile a bit as i think I can get to liking what that profile will do for my beans, roasting a pound at a time, and I want to stick with roasting a single bean and not a blend, at least for the next 5 pounds
Jake
Reddick Fla.
shakin_jake
Postby IMAWriter on Thu Aug 21, 2008 10:16 am
Sounds like a plan.
Seems we've gone a bit off topic (no mention of decaf lately), so apologies to the OP! :oops:
There are terrific decaf's out there, especially those called WP (not Swiss Water).
Espresso blends like Sweet Maria's Donkey Blend get very chocolate-y with milk.
Not bad straight, but in a cappa...yum.
As I mentioned earlier, in the Behmor, as in most any other roasting system, first crack will occur earlier, due in part to the lack of a protective chaff layer and other factors due to the decaffeinating process.
A P2 or P3 would be a better way to go, I believe, if only to allow some stretch time. The beans will appear to be darker than they actually have been roasted...what I mean is the roast degree is a bit less than the color indicates...whew!
LISTEN for the advent of 2nd. Decaf's (IMHO) seem to take to a slightly darker roast, maybe due to a less fruity beginning.
As always, don't stray too far from your Behmor, or anyroaster, for that matter.
I encourage everyone to try a P3 roast sometime...12oz at the 1#/P3 C. No time adjustments necessary, though YMMV due to voltage, ambient temperature, etc.
Roast on wit-cha bad selves!
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby trix on Thu Aug 21, 2008 8:46 pm
I went ahead and changed the thread title. Actually, I am interested in roasting both decaf and reg. I've been following along, enjoying your suggestions and experience as I want to learn to roast both in the Behmor.
I mainly drink a decaf cappa in the AM...I am naturally hyper enough. My husband, being the opposite, requires his 2 large cups of full caff coffee first thing in the morning....he drinks an espresso in mid to late afternoon.
I bought a few different MC decaf green beans last time, (from Theta Ridge); it roasted well and has been quite nice. Since I drink only one decaf cappa each morning I am reluctant to roast 12 oz at a time so it stays fresh enough. My husband or I can easily roast 12 oz for him....since he goes through so much coffee each week.
Lucy
LMWDP #166
trix
Postby IMAWriter on Thu Aug 21, 2008 9:10 pm
Try the WP's:SM's, Coffee bean Corral, Burmans and several others carry them. The Guatemala and Panama are very very good.
Expect roasted decaf to age somewhat faster than regular. Not sure quite why, but it generally does.
Rob
LMWDP #187
www.robertjason.com
IMAWriter
Postby shakin_jake on Fri Aug 22, 2008 12:56 am
whaaa?, I hijacked a thread?!? sorry Trix, my bad... too used to yahoo groups, and as I mentioned before, I'm not much of a computer person so my etiquete isn't where it should be. you'll forgive me right?=:-)
the papau new guinea I just roasted, the pound of beans on 1/P2/B, came out nice. pulled half a dozen shots today. if this brew is going to get better with 2 days more rest, I'll be estatic=:-), but by that time, most of the beans will have been ground and brewed=:-(
12oz at the 1/P3/C sounds like fun, I'll get around to trying it but I'm still undecided what to order for the next 5 pounds of beans. I'm not asking for suggestions, I'm just expressing that I'm not decided yet. I do know that I want to stay with cheaper (lower cost) beans, if for no better reason than to try and contain my initial experimentation with beans in the same quality caliber. Who knows?, maybe one day I'll splurge and roast some more expensive beans but I figure I have time on my side, in that, there's room down the road for more experimentation, and the current crop of beans (meaning all I've roasted to date) have tasted mighty fine
Jake
Reddick Fla.
shakin_jake
Postby trix on Tue Aug 26, 2008 8:51 am
OT
Hey Jason,
You mentioned your kids watching OZ on a different thread.... if you like musicals...you might like to listen to BBC Radio Wales online: Showtime. It is on at 5pm to 6pm EST Sat...or anytime after that with their listen again feature until the next program. I haven't found anything like it in the states. ( I also like Celtic Heartbeat on the same station)
I should be roasting again within the next few days. I ordered some of the WP decaf as you suggested from Burman. I have been happy with my last roast of the MC beans I got from Kevin. I don't think they taste decaffy....the roasted beans have a nice aroma too.
Lucy
LMWDP #166
trix
Postby trix on Fri Sep 26, 2008 9:55 am
I had to call the power company out to fix my voltage. I had some fluctuations that went as low as 106 and 109...with the higher range only at 114 -116. They found the problem now I am averaging around 120.
Ron (or other Behmor roasters),
I just tried 12oz of Daterra Sweet Collection at 1#P3-C (as your suggested profile). Maybe it was my higher voltage but I think it got too shiny dark (to my less than trained eye). I'd say it is chestnut dark brown colored. I should have pushed cool when I thought I should have a little after the 2nd crack; but I didn't. IT did start to smoke for a bit.
I have an Italian cousin coming in on Tuesday and I think he may say it is burnt. I need to try for a more medium roast for him. How soon after the 2nd crack should I hit cool? Oh, and is it after the second crack starts or later into it? I also intend to roast some small quantities of Yirg, Sumatra, and a little robusta...just in case. I ran out of my central American varieties.
A couple of days ago I roasted my Burman's BCT Espresso Blend WP at 6 oz 1/2#P#-C and it came out a nice medium roast.
Lucy
LMWDP #166
trix
PreviousNext
Return to Home Roasting
